Datasheet ADG1334 (Analog Devices) - 8
Description | Quad SPDT ±15 V/+12 V Switches |
Pages / Page | 12 / 8 — ADG1334. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 600. TA = 25. VDD = … |
File Format / Size | PDF / 319 Kb |
ADG1334. TYPICAL PERFORMANCE CHARACTERISTICS. 200. 600. TA = 25. VDD = 12V. 180. VSS = 0V. 500. 160. TA = +85. 140. DD = +15V. 400. SS = –15V. 120. 100
ADG1334 TYPICAL PERFORMANCE CHARACTERISTICS 200 600 TA = 25
C VDD = 12V 180 VSS = 0V 500 160 TA = +85
C ) V 140 DD = +15V )
Ω Ω
V ( 400 SS = –15V ( CE 120 CE AN AN 100 300 IST IST S S 80 RE RE N N 200 O 60 O TA = –40
C TA = +25
C 40 100 20
07 10 0 0 4- 4- 74 74
0
05
0
05
–15 –12 –9 –6 –3 0 3 6 9 12 15 0 2 4 6 8 10 12 SOURCE OR DRAIN VOLTAGE (V) SOURCE OR DRAIN VOLTAGE (V)
Figure 3. On Resistance as a Function of VD (VS ) for Dual Supply Figure 6. On Resistance as a Function of VD (VS ) for Different Temperatures, Single Supply
450 6 TA = 25
C TA = +25
C VDD = +15V 400 VSS = –15V 4 350 V ) C) DD = +5V
Ω
p VSS = –5V ( 300 2 N ( CE V IO DD = 12V 250 AN VSS = 0V CT JE 0 V IST DD = +12V S 200 N I VSS = 0V E RE N 150 –2 O ARG CH 100 –4 50
08 1 0 1 0 4- 4- 74 74
0
05
–6
05
0 2 4 6 8 10 12 –15 –10 –5 0 5 10 15 SOURCE OR DRAIN VOLTAGE (V) VS (V)
Figure 4. On Resistance as a Function of VD (VS ) for Single Supply Figure 7. Charge Injection vs. Source Voltage
250 160 VDD = +15V VDD = +15V VSS = –15V V 140 SS = –15V 200 T 120 ON )
Ω
( 100 CE 150 ) s AN T n T A = +85
C ( OFF E 80 IST S M TI 100 RE 60 N TA = +25
C O TA = –40
C 40 50
09
20
5 0 0 0 4- 4- 74 74
0
05
0
05
–15 –10 –5 0 5 10 15 –40 –20 0 20 40 60 80 SOURCE OR DRAIN VOLTAGE (V) TEMPERATURE (
C)
Figure 5. On Resistance as a Function of VD (VS ) for Different Figure 8. TON/TOFF Time vs. Temperature Temperatures, Dual Supply Rev. 0 | Page 8 of 12 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
