Datasheet ADG417 (Analog Devices) - 3
DescriptionLC2MOS Precision Mini-DIP Analog Switch
Pages / Page8 / 3 — ADG417. Single Supply1(VDD = +12 V. 10%, VSS = 0 V, VL = +5 V. 10%, GND = …
File Format / SizePDF / 97 Kb
ADG417. Single Supply1(VDD = +12 V. 10%, VSS = 0 V, VL = +5 V. 10%, GND = 0 V, unless otherwise noted). B Version. T Version. –40
ADG417 Single Supply1(VDD = +12 V 10%, VSS = 0 V, VL = +5 V 10%, GND = 0 V, unless otherwise noted) B Version T Version –40
C to –55
C to Parameter +25
C +85
C +25
C +125
C Units Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 to VDD 0 to VDD V RON 40 40 Ω typ VD = +3 V, +8.5 V, IS = –10 mA 60 70 Ω max VDD = +10.8 V LEAKAGE CURRENT VDD = +13.2 V Source OFF Leakage IS (OFF) ±0.1 ±0.1 nA typ VD = 12.2 V/1 V, VS = 1 V/12.2 V; ±0.25 ±5 ±0.25 ±15 nA max Test Circuit 2 Drain OFF Leakage ID (OFF) ±0.1 ±0.1 nA typ VD = 12.2 V/1 V, VS = 1 V/12.2 V; ±0.25 ±5 ±0.25 ±15 nA max Test Circuit 2 Channel ON Leakage ID, IS (ON) ±0.1 ±0.1 nA typ VS = VD = 12.2 V/1 V; ±0.4 ±5 ±0.4 ±30 nA max Test Circuit 3 DIGITAL INPUTS Input High Voltage, VINH 2.4 2.4 V min Input Low Voltage, VINL 0.8 0.8 V max Input Current I ± INL or IINH 0.005 ±0.005 µA typ VIN = VINL or VINH ±0.5 ±0.5 µA max DYNAMIC CHARACTERISTICS2 tON 180 250 180 250 ns max RL = 300 Ω, CL = 35 pF; VS = +8 V; Test Circuit 4 tOFF 85 110 85 110 ns max RL = 300 Ω, CL = 35 pF; VS = +8 V; Test Circuit 4 Charge Injection 11 11 pC typ VS = 0 V, RS = 0 Ω, CL = 10 nF; Test Circuit 5 OFF Isolation 80 80 dB typ RL = 50 Ω, f = 1 MHz; Test Circuit 6 CS (OFF) 13 13 pF typ CD (OFF) 13 13 pF typ CD, CS (ON) 65 65 pF typ POWER REQUIREMENTS VDD = +13.2 V IDD 0.0001 0.0001 µA typ VIN = 0 V or 5 V 1 2.5 1 2.5 µA max IL 0.0001 0.0001 µA typ VL = +5.5 V 1 2.5 1 2.5 µA max NOTES 1Temperature ranges are as follows: B Version: –40°C to +85°C; T Version: –55°C to +125°C. 2Guaranteed by design, not subject to production test. Specifications subject to change without notice.
Table I. Truth Table PIN CONFIGURATION DIP/SOIC Logic Switch Condition
0 ON 1 OFF
S 1 8 D NC 2 ADG417 7 VSS TOP VIEW GND 3 (Not to Scale) 6 IN ORDERING GUIDE V 4 5 V DD L Model Temperature Range Package Options* NC = NO CONNECT
ADG417BN –40°C to +85°C N-8 ADG417BR –40°C to +85°C SO-8 *N = Plastic DIP, SO = 0.15" Small Outline IC (SOIC). REV. A –3–
