Datasheet ADG419 (Analog Devices)
Description | LC2MOS Precision Mini-DIP Analog Switch |
Pages / Page | 16 / 1 — LC2MOS Precision. Mini-DIP Analog Switch. ADG419. FEATURES. FUNCTIONAL … |
Revision | B |
File Format / Size | PDF / 319 Kb |
LC2MOS Precision. Mini-DIP Analog Switch. ADG419. FEATURES. FUNCTIONAL BLOCK DIAGRAM. 44 V supply maximum ratings
LC2MOS Precision Mini-DIP Analog Switch ADG419 FEATURES FUNCTIONAL BLOCK DIAGRAM 44 V supply maximum ratings D S2 VSS to VDD analog signal range Low on resistance: <35 Ω S1 Ultralow power dissipation: < 35 μW IN Fast transition time: 160 ns maximum ADG419 Break-before-make switching action
1
SWITCH SHOWN FOR A
-00 50
Plug-in replacement for DG419 LOGIC 1 INPUT
78 0 Figure 1.
APPLICATIONS Precision test equipment Precision instrumentation Battery-powered systems Sample hold systems GENERAL DESCRIPTION
The ADG419 is a monolithic CMOS SPDT switch. This switch
PRODUCT HIGHLIGHTS
is designed on an enhanced LC2MOS process that provides low 1. Extended Signal Range. power dissipation yet gives high switching speed, low on resistance, The ADG419 is fabricated on an enhanced LC2MOS and low leakage currents. process, giving an increased signal range that extends to The on resistance profile of the ADG419 is very flat over the full the supply rails. analog input range, ensuring excellent linearity and low distortion. 2. Ultralow Power Dissipation. The part also exhibits high switching speed and high signal 3. Low RON. bandwidth. CMOS construction ensures ultralow power 4. Single-Supply Operation. dissipation, making the parts ideally suited for portable and For applications where the analog signal is unipolar, the battery-powered instruments. ADG419 can be operated from a single rail power supply. Each switch of the ADG419 conducts equally well in both The part is fully specified with a single 12 V power supply directions when on and has an input signal range that extends and remains functional with single supplies as low as 5 V. to the supplies. In the off condition, signal levels up to the supplies are blocked. The ADG419 exhibits break-before-make switching action.
Rev. B Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2009 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
