Datasheet ADG419 (Analog Devices) - 5
DescriptionLC2MOS Precision Mini-DIP Analog Switch
Pages / Page16 / 5 — ADG419. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter Rating. ESD CAUTION
RevisionB
File Format / SizePDF / 319 Kb
ADG419 ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION
link to page 5
TA= 25°C unless otherwise noted. Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress
Table 3.
rating only; functional operation of the device at these or any
Parameter Rating
other conditions above those indicated in the operational VDD to VSS 44 V section of this specification is not implied. Exposure to absolute VDD to GND −0.3 V to +25 V maximum rating conditions for extended periods may affect VSS to GND +0.3 V to −25 V device reliability. VL to GND −0.3 V to VDD + 0.3 V Analog, Digital Inputs1 VSS − 2 V to VDD + 2 V or 30 mA, whichever
ESD CAUTION
occurs first Continuous Current, S or D 30 mA Peak Current, S or D (Pulsed at 1 ms, 100 mA 10% Duty-Cycle Maximum) Operating Temperature Range Industrial (B Version) −40°C to +125°C Extended (T Version) −55°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C CERDIP Package, Power Dissipation 600 mW θJA, Thermal Impedance 110°C/W Lead Temperature, Soldering (10 sec) 300°C PDIP Package, Power Dissipation 400 mW θJA, Thermal Impedance 100°C/W Lead Temperature, Soldering (10 sec) 260°C SOIC Package, Power Dissipation 400 mW θJA, Thermal Impedance 155°C/W MSOP Package, Power Dissipation 315 mW θJA, Thermal Impedance 205°C/W Lead Temperature, Soldering Vapor Phase (60 sec) 215°C Infrared (15 sec) 220°C 1Overvoltages at IN, S or D is clamped by internal diodes. Limit current to the maximum ratings given. Rev. B | Page 5 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS TERMINOLOGY OUTLINE DIMENSIONS ORDERING GUIDE
