Datasheet ADG419-EP (Analog Devices) - 5
DescriptionLC2MOS Precision Analog Switch in MSOP
Pages / Page12 / 5 — ADG419-EP. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter Rating. ESD …
File Format / SizePDF / 198 Kb
ADG419-EP. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter Rating. ESD CAUTION
ADG419-EP ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION
link to page 5
TA= 25°C, unless otherwise noted. Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress
Table 3.
rating only; functional operation of the device at these or any
Parameter Rating
other conditions above those indicated in the operational VDD to VSS 44 V section of this specification is not implied. Exposure to absolute VDD to GND −0.3 V to +25 V maximum rating conditions for extended periods may affect VSS to GND +0.3 V to −25 V device reliability. VL to GND −0.3 V to VDD + 0.3 V Only one maximum rating may be applied at any one time. Analog, Digital Inputs1 VSS − 2 V to VDD + 2 V or 30 mA, whichever occurs first
ESD CAUTION
Continuous Current, Sx or D 30 mA Peak Current, Sx or D (Pulsed at 1 ms, 100 mA 10% Duty Cycle Maximum) Operating Temperature Range −55°C to +125°C Storage Temperature Range −65°C to +150°C Junction Temperature 150°C Power Dissipation (MSOP) 315 mW Thermal Impedance, θ JA 205°C/W Lead Temperature, Soldering As per JEDEC J-STD-020 1 Overvoltages at IN, Sx, or D are clamped by internal diodes. Limit current to the maximum ratings given. Rev. 0 | Page 5 of 12 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
