Datasheet ADG419-EP (Analog Devices) - 7
DescriptionLC2MOS Precision Analog Switch in MSOP
Pages / Page12 / 7 — ADG419-EP. TYPICAL PERFORMANCE CHARACTERISTICS. 100. TA = 25°C. DD = +5V. …
File Format / SizePDF / 198 Kb
ADG419-EP. TYPICAL PERFORMANCE CHARACTERISTICS. 100. TA = 25°C. DD = +5V. A = 25°C. VSS = –5V. VDD = 5V. VSS = 0V. VDD = +10V. SS = –10V
ADG419-EP TYPICAL PERFORMANCE CHARACTERISTICS 100 TA = 25°C DD = +5V A = 25°C VSS = –5V VDD = 5V VSS = 0V VDD = +10V SS = –10V
ADG419-EP TYPICAL PERFORMANCE CHARACTERISTICS 50 100 TA = 25°C V T DD = +5V A = 25°C VSS = –5V VDD = 5V 40 80 VSS = 0V 30 60 ) VDD = +10V ) (Ω V V SS = –10V ( DD = 10V V ON ON SS = 0V VDD = 12V R V R SS = 0V 20 40 VDD = +12V 10 VSS = –12V 20 VDD = +15V V VDD = 15V SS = –15V VSS = 0V 0 0
3 6
–15 –10 –5 0 5 10 15
00
0 5 10 15
00 6- 6-
VS, VD (V)
84
VS, VD (V)
84 08 08 Figure 3. RON as a Function of VD (VS), Dual-Supply Voltage Figure 6. RON as a Function of VD (VS), Single-Supply Voltage
45 70 VDD = +15V VDD = 12V VSS = –15V VSS = 0V 40 GND = 0V GND = 0V V 60 L = +5V VL = 5V 35 50 30 T ) ) A = +125°C TA = +125°C ( ( 25 40 TA = +85°C ON T ON R A = +85°C R 20 TA = +25°C TA = +25°C 30 15 T T A = –40°C A = –40°C 20 10 TA = –55°C TA = –55°C 5 10
4 7
00
0 2 4 6 8 10 12
00 6- 6-
VS, VD (V)
84
VS, VD (V)
84 08 08 Figure 4. RON as a Function of VD (VS) for Different Temperatures, Figure 7. RON as a Function of VD (VS) for Different Temperatures, Dual-Supply Voltage Single-Supply Voltage
10 6 VDD = +16.5V VDD = 13.2V 9 VSS = –16.5V VSS = 0V 8 GND = 0V 5 GND = 0V +, –: VD = +15.5V/VS = –15.5V +, –: VD = 12.2V/VS = 1V 7 –, +: VD = –15.5V/VS = +15.5V –, +: VD = 1V/VS = 12.2V A) +, +: V A) 4 +, +: V 6 D = +15.5V/VS = +15.5V D = 12.2V/VS = 12.2V (n –, –: V (n D = –15.5V/VS = –15.5V –, –: VD = 1V/VS = 1V ID, IS (ON) +, + NT 5 NT E E 3 4 ID, IS (ON) +, + CURR 3 CURR E E 2 IS (OFF) +, – 2 AG IS (OFF) +, – AG I AK 1 AK D, IS (ON) –, – E E 1 L L 0 –1 0 ID (OFF) –, + –2 IS (OFF) –, + ID, IS (ON) –, – –3 –1 0 5 0 5 0 5 0 5
07
0 5 0 5 0 5 0 5
08
10 15 20 25 30 35 40 45 50 55 60 65 70 75 80 85 90 95
1
1
10 10 11 11 12 12
6-
10 10 11 11 12 12
6-
TEMPERATURE (°C)
84
TEMPERATURE (°C)
84 08 08 Figure 5. Leakage Current vs. Temperature, Dual-Supply Voltage Figure 8. Leakage Current vs. Temperature, Single-Supply Voltage Rev. 0 | Page 7 of 12 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
