Datasheet ADG411, ADG412, ADG413 (Analog Devices) - 7
DescriptionLC2MOS Precision Quad SPST Switches
Pages / Page16 / 7 — ADG411/ADG412/ADG413. TYPICAL PERFORMANCE CHARACTERISTICS. A = 25°C. A = …
RevisionD
File Format / SizePDF / 222 Kb
ADG411/ADG412/ADG413. TYPICAL PERFORMANCE CHARACTERISTICS. A = 25°C. A = 25. L = +5V. VDD = +5V. VSS = 0V. DD = +5V. DD = +10V. SS = –5V
ADG411/ADG412/ADG413 TYPICAL PERFORMANCE CHARACTERISTICS A = 25°C A = 25 L = +5V VDD = +5V VSS = 0V DD = +5V DD = +10V SS = –5V
ADG411/ADG412/ADG413 TYPICAL PERFORMANCE CHARACTERISTICS 50 50 T T A = 25°C A = 25
C V V L = +5V L = +5V VDD = +5V 40 40 VSS = 0V V V DD = +5V DD = +10V V V SS = –5V SS = 0V 30 30 V ) DD = +12V )
Ω Ω
V V SS = 0V DD = +10V ( ( VSS = –10V VDD = +12V ON ON VSS = –12V R R 20 20 10 10 V V DD = +15V DD = +15V V V SS = 0V SS = –15V 0
00024-008
0
00024-005
0 5 10 15 20 –20 –10 0 10 20 V V D OR VS – DRAIN OR SOURCE VOLTAGE (V) D OR VS – DRAIN OR SOURCE VOLTAGE (V)
Figure 5. On Resistance as a Function of V Figure 8. On Resistance as a Function of VD (VS) Single Supply D (VS) Dual Supplies
50 100m VDD = +15V 4 SW VDD = +15V VSS = –15V 1 SW VSS = –15V VL = +5V VL = +5V 10m 40 1m 30 I+, I– )
Ω
(A) ( 100
μ
ON PPLY R 20 125
C I SU 10
μ
85
C IL 25
C 10 1
μ 00024-009
0
00024-006
100n –20 –15 –10 –5 0 5 10 15 20 10 100 1k 10k 100k 1M 10M V FREQUENCY (Hz) D OR VS – DRAIN OR SOURCE VOLTAGE (V)
Figure 9. Supply Current vs. Input Switching Frequency Figure 6. On Resistance as a Function of VD (VS) for Different Temperatures
0.04 10 VDD = +15V V V DD = +15V SS = –15V V T ID (ON) SS = –15V A = 25°C V V L = +5V L = +5V 0.02 1 IS (OFF) VD =
15V IS (OFF) NT (nA) V NT (nA) S =
15V 0 0.1 CURRE CURRE ID (OFF) ID (OFF) AKAGE AKAGE ID (ON) LE –0.02 LE 0.01 –0.04
00024-010
0.001
00024-007
–20 –10 0 10 20 100 1k 10k 100k 1M 100M VD OR VS – DRAIN OR SOURCE VOLTAGE (V) FREQUENCY (Hz)
Figure 7. Leakage Currents as a Function of Temperature Figure 10. Leakage Currents as a Function of VD (VS) Rev. D | Page 7 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAMS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY APPLICATIONS TEST CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
