Typical Performance Characteristics–ADG511/ADG512/ADG5135010mAVDD = +5VTA = 25CVSS = –5V1mA40100AV30DD = +3VI–, I+VSS = –3V–10AONRI SUPPLY201AVDD = +5V1 SWV4 SW10SS = –5V100nA010nA–5–4–3–2–1012345101001k10k100k1M10MVFREQUENCY – HzD OR VS – DRAIN OR SOURCE VOLTAGE – V TPC 1. On Resistance as a Function of V TPC 4. Supply Current vs. Input Switching Frequency D (VS) Dual Supplies 5010VVDD = +5VDD = +5VVVSS = –5VSS = –5VVS =5V40IVD (OFF)D =5V1nA –30125C–0.1ONR85C2025CID (ON)LEAKAGE CURRENT 0.0110IS (OFF)00.001–5–4–3–2–10123452535455565758595105115125VD OR VS – DRAIN OR SOURCE VOLTAGE – VTEMPERATURE –C TPC 2. On Resistance as a Function of VD (VS) for TPC 5. Leakage Currents as a Function of Temperature Different Temperatures 90120TA = 25CVDD = +5V80VSS = –5VVDD = 3V V10070SS = 0VdB –60–80ONR 50VOFF ISOLATION40DD = 5VVSS = 0V603020400123451001k10k100k1M10MVD OR VS – DRAIN OR SOURCE VOLTAGE – VFREQUENCY – Hz TPC 3. On Resistance as a Function of V TPC 6. Off Isolation vs. Frequency D (VS) Single Supply REV. C –7–
