Datasheet ADG508A, ADG509A (Analog Devices)
Description | CMOS 4-/8-Channel Analog Multiplexers |
Pages / Page | 16 / 1 — CMOS 4-/8-Channel. Analog Multiplexers. ADG508A/ADG509A. FEATURES. … |
Revision | D |
File Format / Size | PDF / 390 Kb |
CMOS 4-/8-Channel. Analog Multiplexers. ADG508A/ADG509A. FEATURES. FUNCTIONAL BLOCK DIAGRAMS. 44 V supply maximum rating. ADG508A
CMOS 4-/8-Channel Analog Multiplexers ADG508A/ADG509A FEATURES FUNCTIONAL BLOCK DIAGRAMS 44 V supply maximum rating ADG508A VSS to VDD analog signal range Single-/dual-supply specifications S1 D Wide supply range: 10.8 V to 16.5 V Extended plastic temperature range: −40°C to +85°C Low power dissipation: 28 mW maximum Low leakage: 20 pA typical S8 Available in 16-lead DIP/SOIC and 20-lead PLCC/LCC packages DECODER Superior alternative to
1 00 1-
DG508A, HI-508 A0 A1 A2 EN
05 00
DG509A, HI-509
Figure 1. ADG508A
ADG509A S1A DA S4A S1B DB S4B DECODER
02 0 1- 5
A0 A1 EN
0 00 Figure 2. ADG509A
GENERAL DESCRIPTION PRODUCT HIGHLIGHTS
The ADG508A and ADG509A are CMOS monolithic analog 1. Single-/Dual-Supply Specifications with a Wide Tolerance. multiplexers with eight channels and dual four channels, respec- The devices are specified in the 10.8 V to 16.5 V range for tively. The ADG508A switches one of eight inputs to a common both single and dual supplies. output, depending on the state of three binary addresses and an 2. Extended Signal Range. The enhanced LC2MOS processing enable input. The ADG509A switches one of four differential results in a high breakdown and an increased analog signal inputs to a common differential output, depending on the state range of VSS to VDD. of two binary addresses and an enable input. Both devices have 3. Break-Before-Make Switching. Switches are guaranteed TTL and 5 V CMOS logic-compatible digital inputs. break-before-make so that input signals are protected The ADG508A and ADG509A are designed on an enhanced against momentary shorting. LC2MOS process that gives an increased signal capability of VSS 4. Low Leakage. Leakage currents in the range of 20 pA make to VDD and enables operation over a wide range of supply voltages. these multiplexers suitable for high precision circuits. The devices can comfortably operate anywhere in the 10.8 V to 16.5 V single- or dual-supply range. These multiplexers also feature high switching speeds and low RON.
Rev. D Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2009 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS SINGLE-SUPPLY OCTAL DAC APPLICATION OUTLINE DIMENSIONS ORDERING GUIDE
