Datasheet ADG508A, ADG509A (Analog Devices) - 3
DescriptionCMOS 4-/8-Channel Analog Multiplexers
Pages / Page16 / 3 — ADG508A/ADG509A. SPECIFICATIONS DUAL SUPPLY. Table 1. ADG508A/. ADG509A. …
RevisionD
File Format / SizePDF / 390 Kb
ADG508A/ADG509A. SPECIFICATIONS DUAL SUPPLY. Table 1. ADG508A/. ADG509A. K Version. B Version. T Version. −40°C to. −55°C to. Parameter
ADG508A/ADG509A SPECIFICATIONS DUAL SUPPLY Table 1 ADG508A/ ADG509A K Version B Version T Version −40°C to −55°C to Parameter
link to page 11 link to page 11 link to page 11 link to page 11 link to page 11 link to page 4 link to page 11 link to page 4 link to page 12 link to page 4 link to page 12 link to page 4 link to page 12
VDD = 10.8 V to 16.5 V, VSS = −10.8 V to −16.5 V, unless otherwise noted.
Table 1. ADG508A/ ADG508A/ ADG508A/ ADG509A ADG509A ADG509A K Version B Version T Version −40°C to −40°C to −55°C to Parameter +25°C +85° +25°C +85°C +25°C +125°C Unit Comments
ANALOG SWITCH Analog Signal Range VSS VSS VSS VSS VSS VSS V min VDD VDD VDD VDD VDD VDD V max RON 280 280 280 Ω typ −10 V ≤ VS ≤ +10 V, IDS = 1 mA; see Figure 14 450 600 450 600 450 600 Ω max 300 400 300 400 Ω max VDD = 15 V (±10%), VSS = −15 V (±10%) 300 400 Ω max VDD = 15 V (±5%), VSS = −15 V (±5%) RON Drift 0.6 0.6 0.6 %/°C typ VS = 0, IDS = 1 mA RON Match 5 5 5 % typ −10 V ≤ VS ≤ +10 V, IDS = 1 mA IS (Off ), Off Input Leakage 0.02 0.02 0.02 nA typ V1 = ±10 V, V2 = m 10 V; see Figure 15 1 50 1 50 1 50 nA max ID (Off), Off Output Leakage 0.04 0.04 0.04 nA typ V1 = ±10 V, V2 = m 10 V; see Figure 16 ADG508A 1 100 1 100 1 100 nA max ADG509A 1 50 1 50 1 50 nA max ID (On), On Channel Leakage 0.04 0.04 0.04 nA typ V1 = V2 = ±10 V; see Figure 17 ADG508A 1 100 1 100 1 100 nA max ADG509A 1 50 1 50 1 50 nA max IDIFF, Differential Off Output 25 25 25 nA max V1 = ±10 V, V2 = m 10 V; Leakage (ADG509A Only) see Figure 18 DIGITAL CONTROL VINH, Input High Voltage 2.4 2.4 2.4 V min VINL, Input Low Voltage 0.8 0.8 0.8 V max IINL or IINH 1 1 1 μA max VIN = 0 to VDD CIN Digital Input Capacitance 8 8 8 pF max DYNAMIC CHARACTERISTICS t 1 TRANSITION 200 200 200 ns typ V1 = ±10 V, V2 = m 10 V; see Figure 19 300 400 300 400 300 400 ns max t 1 OPEN 50 50 50 ns typ See Figure 20 25 10 25 10 25 10 ns min tON (EN)1 200 200 200 ns typ See Figure 21 300 400 300 400 300 400 ns max tOFF (EN)1 200 200 200 ns typ See Figure 21 300 400 300 400 300 400 ns max OffF Isolation 68 68 68 dB typ VEN = 0.8 V, RL = 1 kΩ, CL = 15 pF, VS = 7 V rms, f = 100 kHz 50 50 50 dB min Rev. D | Page 3 of 16 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS SINGLE-SUPPLY OCTAL DAC APPLICATION OUTLINE DIMENSIONS ORDERING GUIDE
