Datasheet ADG508A, ADG509A (Analog Devices) - 10
DescriptionCMOS 4-/8-Channel Analog Multiplexers
Pages / Page16 / 10 — ADG508A/ADG509A. TYPICAL PERFORMANCE CHARACTERISTICS. 700. 600. VDD = …
RevisionD
File Format / SizePDF / 390 Kb
ADG508A/ADG509A. TYPICAL PERFORMANCE CHARACTERISTICS. 700. 600. VDD = +5V. 500. VSS = –5V. VDD = 10.8V VSS = 0V. ) 400. 400. R 300. 300
ADG508A/ADG509A TYPICAL PERFORMANCE CHARACTERISTICS 700 600 VDD = +5V 500 VSS = –5V VDD = 10.8V VSS = 0V ) 400 400 R 300 300
link to page 11
The multiplexers are guaranteed functional with reduced single or dual supplies down to 4.5 V.
700 700 600 600 VDD = +5V 500 VSS = –5V 500 VDD = 10.8V VSS = 0V ) 400 ) 400 ( ( ON ON R 300 R V 300 DD = +10.8V VSS = –10.8V VDD = 15V 200 200 VSS = 0V V 100 DD = +15V V 100 SS = –15V 0 0
2
–20 –15 –10 –5 0 5 10 15 20
09 0
-01 1-
V
51
D [VS] (V)
05
VD [VS] (V)
00 000 Figure 8. RON as a Function of VD (VS): Dual-Supply Voltage, TA = 25°C Figure 11. RON as a Function of VD (VS) Single-Supply Voltage, TA = 25°C
100 1.9 VDD = +16.5V VSS = –16.5V 10 A) 1.8 n ) ( V T ( N I L D (ON) E I V RRE D (OFF) 1 LE 1.7 CU R E IGGE R AKAG T E IS (OFF) L 0.1 1.6 1.5 25 35 45 55 65 75 85 95 105 115 125
10 0
5 6 7 8 9 10 11 12 13 14
13 0
15
1- 1-
TEMPERATURE (°C)
05
SUPPLY VOLTAGE (V)
05 00 00 Figure 9. Leakage Current as a Function of Temperature Figure 12. Trigger Levels vs. Power Supply Voltage, Dual or Single Supply, (Note: Leakage Currents Reduce as the Supply Voltages Reduce) TA = 25°C
800 1.0 700 0.8 600 s) (n 0.6 500 ) N A IO IT SINGLE (m S 400 SUPPLY I DD RAN 0.4 t T DUAL 300 SUPPLY 0.2 200 100 0
4
5 6 7 8 9 10 11 12 13 14 15
11 0
5 6 7 8 9 10 11 12 13 14 15 16
01
17
1- 1-
SUPPLY VOLTAGE (V)
05
SUPPLY VOLTAGE (V)
05 00 00 Figure 10. tTRANSITION vs. Supply Voltage: Dual and Single Supplies, TA = 25°C Figure 13. IDD vs. Supply Voltage: Dual or Single Supply, TA = 25°C (Note: For VDD and lVSSl < 10 V; V1 = VDD/VSS, V2 = VSS/VDD. (see Figure 19)) Rev. D | Page 10 of 16 Document Outline FEATURES FUNCTIONAL BLOCK DIAGRAMS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DUAL SUPPLY SINGLE SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS SINGLE-SUPPLY OCTAL DAC APPLICATION OUTLINE DIMENSIONS ORDERING GUIDE
