Datasheet EL8202, EL8203, EL8403 (Renesas) - 7
ManufacturerRenesas
Description500MHz Rail-to-Rail Amplifiers
Pages / Page16 / 7 — Typical Performance Curves. (Continued). 100. 3.5. RL=1k. CL=1.5pF. V=1. …
Typical Performance Curves. (Continued). 100. 3.5. RL=1k. CL=1.5pF. V=1. 2.5. ING (dB). 1.5. IMPEDANCE (. 0.1. AV=2. 0.5. 0.01. 10K. 100K. 10M. 100M. 4.5. 5.5
Typical Performance Curves (Continued) 100 3.5 RL=1k CL=1.5pF V=1 2.5 ING (dB) 1.5 IMPEDANCE ( 0.1 AV=2 0.5 0.01 10K 100K 10M 100M 4.5 5.5
Typical Performance Curves (Continued) 100 3.5 RL=1k 3 CL=1.5pF 10 A ) V=1 2.5 2 1 ING (dB) 1.5 AK IMPEDANCE ( PE 1 0.1 AV=2 0.5 0.01 0 10K 100K 1M 10M 100M 3 3.5 4 4.5 5 5.5 FREQUENCY (Hz) VS (V) FIGURE 13. OUPUT IMPEDANCE vs FREQUENCY FIGURE 14. SMALL SIGNAL PEAKING vs SUPPLY VOLTAGE -15 10 -35 8 B) -55 ) 6 d mA ( I S -75 4 CMRR ( -95 2 -115 0 100K 1M 10M 100M 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 5.5 FREQUENCY (Hz) VS (V) FIGURE 15. COMMON-MODE REJECTION RATIO vs FIGURE 16. SUPPLY CURRENT vs SUPPLY VOLTAGE FREQUENCY (PER CHANNEL) -60 -70 VS=5V RL=1k C HD2@10MHz -75 H ) L=2.5pF D -70 2@ A ) A V=2 V=2 dBc HD2@5MHz -80 ( dBc ( HD2 N N @AV=1 IO -80 IO -85 ORT V T HD2@1MHz HD3@10MHz ORT S=5V IS -90 ST f=5MHz HD3 D @ -90 DI AV=2 HD3@5MHz HD3@1MHz -95 V HD O=1VP-P for AV=1 3@A V V=1 O=2VP-P for AV=2 -100 -100 1 2 3 4 5 100 1K 2K VOP-P (V) RLOAD ( ) FIGURE 17. HARMONIC DISTORTION vs OUTPUT VOLTAGE FIGURE 18. HARMONIC DISTORTION vs LOAD RESISTANCE
FN7106 Rev 2.00 Page 7 of 16 April 26, 2006
