Datasheet NCV5230 (ON Semiconductor)
Manufacturer | ON Semiconductor |
Description | Operational Amplifier, Low Voltage |
Pages / Page | 19 / 1 — www.onsemi.com. SOIC−8. D SUFFIX. CASE 751. PIN CONNECTIONS. N, D … |
Revision | 6 |
File Format / Size | PDF / 349 Kb |
www.onsemi.com. SOIC−8. D SUFFIX. CASE 751. PIN CONNECTIONS. N, D Packages. DEVICE MARKING INFORMATION. ORDERING INFORMATION. Features
link to page 15 link to page 15 Operational Amplifier, Low Voltage NCV5230 The NCV5230 is a very low voltage operational amplifier that can perform with a voltage supply as low as 1.8 V or as high as 15 V. In addition, split or single supplies can be used, and the output will swing to ground when applying the latter. There is a bias adjusting pin
www.onsemi.com
which controls the supply current required by the device and thereby controls its power consumption. If the part is operated at ±0.9 V supply voltages, the current required is only 110 mA when the current 8 control pin is left open. Even with this low power consumption, the 1 device obtains a typical unity gain bandwidth of 250 kHz. When the bias adjusting pin is connected to the negative supply, the unity gain
SOIC−8
bandwidth is typically 600 kHz while the supply current is increased
D SUFFIX CASE 751
to 600 mA. In this mode, the part will supply full power output beyond the audio range. The NCV5230 also has a unique input stage that allows the
PIN CONNECTIONS
common−mode input range to go above the positive and below the negative supply voltages by 250 mV. This provides for the largest
N, D Packages
possible input voltages for low voltage applications. The part is also 1 8 NC internally−compensated to reduce external component count. NC The NCV5230 has a low input bias current of typically ±40 nA, and 2 7 −IN V − CC a large open−loop gain of 125 dB. These two specifications are 3 + 6 +IN OUTPUT beneficial when using the device in transducer applications. The large V 4 5 EE BIAS ADJ. open−loop gain gives very accurate signal processing because of the large “excess” loop gain in a closed−loop system. (Top View) The output stage is a class AB type that can swing to within 100 mV of the supply voltages for the largest dynamic range that is needed in many applications. The NCV5230 is ideal for portable audio
equipment and remote transducers because of its low power See general marking information in the device marking consumption, unity gain bandwidth, and 30 nV/√Hz noise section on page 15 of this data sheet. specification.
ORDERING INFORMATION Features
See detailed ordering and shipping information in the package • Works Down to 1.8 V Supply Voltages dimensions section on page 15 of this data sheet. • Adjustable Supply Current • Low Noise • Common−mode Includes Both Rails • VOUT Within 100 mV of Both Rails • These are Pb−Free Devices
Applications
• Portable Precision Instruments • Remote Transducer Amplifier • Portable Audio Equipment • Rail−to−Rail Comparators • Half−wave Rectification without Diodes • Remote Temperature Transducer with 4.0 to 20 mA Output Transmission © Semiconductor Components Industries, LLC, 2010
1
Publication Order Number:
February, 2020 − Rev. 6 NE5230/D
