Datasheet BAS116 (Nexperia) - 6
Manufacturer | Nexperia |
Description | Low-leakage diode |
Pages / Page | 10 / 6 — Nexperia. BAS116. Low-leakage diode. 12. Package outline. Plastic … |
Revision | 05082020 |
File Format / Size | PDF / 205 Kb |
Nexperia. BAS116. Low-leakage diode. 12. Package outline. Plastic surface-mounted package; 3 leads. SOT23
Nexperia BAS116 Low-leakage diode 12. Package outline Plastic surface-mounted package; 3 leads SOT23
D B E A X HE v A 3 Q A A1 1 2 c e1 bp w B Lp e detail X 0 1 2 mm scale Dimensions (mm are the original dimensions) Unit A A1 bp c D E e e1 HE Lp Q v w max 1.1 0.1 0.48 0.15 3.0 1.4 2.5 0.45 0.55 mm nom 1.9 0.95 0.2 0.1 min 0.9 0.38 0.09 2.8 1.2 2.1 0.15 0.45 sot023_po Outline References European version projection Issue date IEC JEDEC JEITA SOT23 14-06-19 TO-236AB 14-09-22
Fig. 7. Package outline SOT23
BAS116 All information provided in this document is subject to legal disclaimers. © Nexperia B.V. 2020. Al rights reserved
Product data sheet 5 August 2020 6 / 10
Document Outline 1. General description 2. Features and benefits 3. Applications 4. Quick reference data 5. Pinning information 6. Ordering information 7. Marking 8. Limiting values 9. Thermal characteristics 10. Characteristics 11. Test information 12. Package outline 13. Soldering 14. Revision history 15. Legal information Contents
