Datasheet MBR2030CTLG (ON Semiconductor) - 2
ManufacturerON Semiconductor
DescriptionSwitch-mode Dual Schottky Power Rectifier
Pages / Page6 / 2 — MBR2030CTLG. MAXIMUM RATINGS. Rating. Symbol. Value. Unit. THERMAL …
File Format / SizePDF / 243 Kb
MBR2030CTLG. MAXIMUM RATINGS. Rating. Symbol. Value. Unit. THERMAL CHARACTERISTICS. Characteristic. ELECTRICAL CHARACTERISTICS. Min. Typ. Max
MBR2030CTLG MAXIMUM RATINGS Rating Symbol Value Unit THERMAL CHARACTERISTICS Characteristic ELECTRICAL CHARACTERISTICS Min Typ Max
link to page 2 link to page 2 link to page 2
(Per Leg)
Peak Repetitive Reverse Voltage VRRM 30 V Working Peak Reverse Voltage VRWM DC Blocking Voltage VR Average Rectified Forward Current IF(AV) A (TC = 167_C) Per Diode 10 Per Device 20 Non-repetitive Peak Surge Current IFSM 150 A (Surge applied at rated load conditions halfwave, single phase, 60 Hz) Peak Repetitive Forward Current IFRM 10 A (Square Wave, 20 kHz, TC = 166°C) Peak Repetitive Reverse Surge Current (2.0 ms, 1.0 kHz) IRRM 1.0 A Operating Junction Temperature (Note 1) TJ *65 to +175 °C Storage Temperature Tstg *65 to +175 °C Voltage Rate of Change (Rated VR) dv/dt 1000 V/ms Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality should not be assumed, damage may occur and reliability may be affected. 1. The heat generated must be less than the thermal conductivity from Junction−to−Ambient: dPD/dTJ < 1/RqJA.
(Per Leg)
Characteristic Symbol Value Unit
Maximum Thermal Resistance, Junction−to−Case (Min. Pad) RqJC 2.0 °C/W Maximum Thermal Resistance, Junction−to−Ambient (Min. Pad) RqJA 60 °C/W
(Per Leg)
Characteristic Symbol Min Typ Max Unit
Maximum Instantaneous Forward Voltage (Note 2) vF V (iF = 10 Amps, TJ= 25°C) − 0.45 0.52 (iF = 10 Amps, TJ = 150°C) − 0.32 0.40 (iF = 20 Amps, TJ = 25°C) − 0.51 0.58 (iF = 20 Amps, TJ = 150°C) − 0.41 0.48 Maximum Instantaneous Reverse Current (Note 2) iR mA (Rated dc Voltage, TJ = 25°C) − 0.11 5.0 (Rated dc Voltage, TJ = 100°C) − 10 40 (Rated dc Voltage, TJ = 125°C) − − 75 Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 2. Pulse Test: Pulse Width = 5.0 ms, Duty Cycle ≤ 10%.
www.onsemi.com 2
