Datasheet VTL5C3, VTL5C4 (PerkinElmer) - 6
ManufacturerPerkinElmer
DescriptionLow Cost Axial Vactrols
Pages / Page26 / 6 — Low Cost Axial Vactrols. VTL5C6, 5C7. PACKAGE DIMENSIONS INCH (MM). …
File Format / SizePDF / 421 Kb
Low Cost Axial Vactrols. VTL5C6, 5C7. PACKAGE DIMENSIONS INCH (MM). PLASTIC POTTING CONTOUR NOT CONTROLLED. DESCRIPTION
Low Cost Axial Vactrols VTL5C6, 5C7 PACKAGE DIMENSIONS INCH (MM) PLASTIC POTTING CONTOUR NOT CONTROLLED DESCRIPTION
VTL5C6 has a large dynamic range, high dark resistance, a low temperature coeffecient of resistance, and a small light history memory. VTL5C7 is a shallow sloped device with good dynamic range, average temperature coefficient of resistance, speed of response, and light history memory.
ABSOLUTE MAXIMUM RATINGS @ 25°C
Maximum Temperatures LED Forward Voltage Drop @ 20 mA: 2.0V (1.65V Typ.) Storage and Operating: –40°C to 75°C Cel Power: 175 mW Min. Isolation Voltage @ 70% Rel. Humidity: 2500 VRMS Derate above 30°C: 3.9 mW/°C Output Cel Capacitance: 5.0 pF LED Current: 40 mA
1
Derate above 30°C: 0.9 mA/°C Cel Voltage: 250V (VTL5C6), 50V (VTL5C7) LED Reverse Breakdown Voltage: 3.0 V Input - Output Coupling Capacitance: 0.5 pF
ELECTRO-OPTICAL CHARCTERISTICS @ 25°C
ON Resistance
2
Dynamic Range Response Time
4
Slope OFF
3
(Typ.) Part Material (Typ.) Dark Turn-off (Decay) Resistance Turn-on to Number Type Input Adapted to (Max.) @ 10 sec. (Min.) R 63% Final R current @ 0.5 mA ON DARK (Typ.) ------------ ------------ (Typ.) R@ 5 mA R@ 20 mA 1 MΩ 100 kΩ 1 mA 75 kΩ VTL5C6 0 10 mA 10 kΩ 100 MΩ 16.7 88 db 3.5 ms 50 ms 40 mA 2 kΩ 0.4 mA 5 kΩ VTL5C7 7 2 mA 1.1 kΩ 1 MΩ 5.7 75 db 6.0 ms 1 sec Refer to Specification Notes, page 41.
PerkinElmer Optoelectronics, 10900 Page Ave., St. Louis, MO 63132 USA Phone: 314-423-4900 Fax: 314-423-3956 Web: www.perkinelmer.com/opto
51
