Datasheet MAX9000, MAX9001, MAX9002, MAX9003, MAX9004, MAX9005 (Analog Devices) - 3
Description | Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs |
Pages / Page | 20 / 3 — Low-Power, High-Speed, Single-Supply. Op Amp + Comparator + Reference … |
File Format / Size | PDF / 255 Kb |
Low-Power, High-Speed, Single-Supply. Op Amp + Comparator + Reference ICs. MAX9000–MAX9005
Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs MAX9000–MAX9005 ELECTRICAL CHARACTERISTICS (continued)
(VDD = +2.5V to +5.5V, VSS = 0, SHDN = VDD (MAX9001/MAX9004 only), VCM(OP AMP) = 0, VAOUT = VDD / 2, VCM(COMP) = 0 (for MAX9001/MAX9002/MAX9004/MAX9005), COUT = low, IOUT(REF) = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at VDD = 5V and TA = +25°C.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
VAOUT = 0.05V to 2.45V, RL = 100kΩ 94 125 VDD = 2.5V VAOUT = 0.2V to 2.3V, RL = 1kΩ 84 115 Large-Signal Voltage Gain AVOL dB VAOUT = 0.05V to 5.4V, RL = 100kΩ 94 120 VDD = 5.5V VAOUT = 0.25V to 5.2V, RL = 1kΩ 86 106 VDD - VOH 1 5 RL = 100kΩ VOL Output Voltage Swing VOL / VOH 1 5 VAIN+ - VAIN- ≥ 10mV mV VDD - VOH 140 250 RL = 1kΩ VOL 60 100 MAX9000/MAX9001/MAX9002 1.25 Gain-Bandwidth Product GBW MHz MAX9003/MAX9004/MAX9005 8 MAX9000/MAX9001/MAX9002 75 Phase Margin degrees MAX9003/MAX9004/MAX9005 80 MAX9000/MAX9001/MAX9002 30 Gain Margin dB MAX9003/MAX9004/MAX9005 40 MAX9000/MAX9001/ 0.009 f = 10kHz, MAX9002 (AV = 1V/V) Total Harmonic Distortion THD+N VAOUT = 2Vp-p, % plus Noise V MAX9003/MAX9004/ DD = 5V 0.028 MAX9005 (AV = 10V/V) MAX9000/MAX9001/ 0.85 V MAX9002 (A DD = 5V, V = 1V/V) Slew Rate SR V/µs VAOUT = 4V step MAX9003/MAX9004/ 6.0 MAX9005 (AV = 10V/V) MAX9000/MAX9001/ 6.9 V MAX9002 (A DD = 5V, V = 1V/V) Settling Time to within 0.01% µs VAOUT = 4V step MAX9003/MAX9004/ 2.1 MAX9005 (AV = 10V/V) Input Capacitance CIN 2.5 pF Input Noise Voltage Density VNOISE f = 10kHz 36 nV/√Hz Input Noise Current Density INOISE f = 10kHz 1 fA/√Hz Shutdown Delay Time 0.2 µs Enable Delay Time 2 µs Power-On Time 2 µs MAX9000/MAX9001/MAX9002 (AV = 1V/V) 250 Capacitive-Load Stability CLOAD pF MAX9003/MAX9004/MAX9005 (AV = 10V/V) 250
COMPARATOR
Input Offset Voltage VOS MAX900_ES_ (Notes 1, 2) ±1 ±2 mV Input Offset Voltage TCVOS MAX900_ES_ ±1 µV/°C Temperature Coefficient Input-Referred Hysteresis VDD = 5V (Notes 2, 3) 4 7 mV
_______________________________________________________________________________________ 3
