Datasheet MAX9000, MAX9001, MAX9002, MAX9003, MAX9004, MAX9005 (Analog Devices) - 5
Description | Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs |
Pages / Page | 20 / 5 — Low-Power, High-Speed, Single-Supply. Op Amp + Comparator + Reference … |
File Format / Size | PDF / 255 Kb |
Low-Power, High-Speed, Single-Supply. Op Amp + Comparator + Reference ICs. MAX9000–MAX9005
Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs MAX9000–MAX9005 __________________________________________Typical Operating Characteristics
(VDD = +5V, VSS = 0, VCM (op amp) = 0, SHDN = VDD, COUT = low, RL = ∞, TA = +25°C, unless otherwise noted.)
SUPPLY CURRENT SHUTDOWN SUPPLY CURRENT SHUTDOWN LOGIC THRESHOLD vs. SUPPLY VOLTAGE vs. SUPPLY VOLTAGE vs. SUPPLY VOLTAGE
500 3.5 2.5 3.0 450 MAX9000/MAX9001/MAX9003/MAX9004 µA) MAX9000 TOC01 MAX9000 TOC02 2.0 MAX9000 TOC03 µA) 2.5 400 2.0 1.5 350 MAX9002/MAX9005 1.5 1.0 300 SUPPLY CURRENT ( 1.0 0.5 250 SHUTDOWN SUPPLY CURRENT ( SHUTDOWN LOGIC THRESHOLD (V) 0.5 200 0 0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 2.5 3.0 3.5 4.0 4.5 5.0 5.5 2.5 3.0 3.5 4.0 4.5 5.0 5.5 SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V)
MAX9000/MAX9001/MAX9003/MAX9004 SHUTDOWN SUPPLY CURRENT SHUTDOWN LOGIC THRESHOLD SUPPLY CURRENT vs. TEMPERATURE vs. TEMPERATURE vs. TEMPERATURE
500 5.0 2.00 4.5 µA) MAX9000 TOC04 4.0 MAX9000 TOC05 V 1.98 DD = 5.5V MAX9000 TOC06 450 µA) VDD = 5.5V 3.5 3.0 1.96 400 2.5 VDD = 2.5V 2.0 1.94 SUPPLY CURRENT ( 1.5 VDD = 2.5V 350 1.0 1.92 SHUTDOWN SUPPLY CURRENT ( SHUTDOWN LOGIC THRESHOLD (V) 0.5 300 0 1.90 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C)
MAX9002/MAX9005 OP-AMP OUTPUT VOLTAGE SWING HIGH (VOH) OP-AMP OUTPUT VOLTAGE SWING LOW (VOL) SUPPLY CURRENT vs. TEMPERATURE vs. SOURCE CURRENT vs. SINK CURRENT
500 450 600 400 TA = +85°C 500 MAX9000 TOC07 350 MAX9000 TOC08 MAX9000 TOC09 T 450 A = +85°C µA) TA = +25°C 300 400 TA = +25°C (mV) 250 OH 400 (mV) V 300 DD = 5.5V - V 200 OLV V DD TA = -40°C 150 200 SUPPLY CURRENT ( 350 T V A = -40°C DD = 2.5V 100 100 50 300 0 0 -40 -20 0 20 40 60 80 100 0 1 2 3 4 5 6 0 2 4 6 8 10 12 14 16 18 20 TEMPERATURE (°C) SOURCE CURRENT (mA) SINK CURRENT (mA)
_______________________________________________________________________________________ 5
