Datasheet MAX9000, MAX9001, MAX9002, MAX9003, MAX9004, MAX9005 (Analog Devices) - 6
Description | Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs |
Pages / Page | 20 / 6 — Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs |
File Format / Size | PDF / 255 Kb |
Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs ____________________________________Typical Operating Characteristics (continued)
(VDD = +5V, VSS = 0, VCM (op amp) = 0, SHDN = VDD, COUT = low, RL = ∞, TA = +25°C, unless otherwise noted.)
CHANGE IN OP-AMP OFFSET VOLTAGE (VOS) CHANGE IN OP-AMP OFFSET VOLTAGE (VOS) OP-AMP COMMON-MODE REJECTION RATIO vs. SUPPLY VOLTAGE vs. TEMPERATURE vs. TEMPERATURE
30 100 92 91 20 MAX9000 TOC10 50 MAX9000 TOC11 MAX9000 TOC12 90 µV) 10 ( µV) ( 89 OS OS 0 0 88 CMRR (dB) -50 87 CHANGE IN V -10 CHANGE IN V 86 -20 -100 85 -30 -150 84
MAX9000–MAX9005
2.5 3.0 3.5 4.0 4.5 5.0 5.5 -40 -20 0 20 40 60 80 100 -40 -20 0 20 40 60 80 100 SUPPLY VOLTAGE (V) TEMPERATURE (°C) TEMPERATURE (°C)
OP-AMP LARGE-SIGNAL GAIN OP-AMP LARGE-SIGNAL GAIN OP-AMP LARGE-SIGNAL GAIN vs. OUTPUT VOLTAGE vs. OUTPUT VOLTAGE vs. TEMPERATURE
140 140 140 VDD = 5.5V R R L TO GND L = 100kΩ 130 R 130 130 L = 100kΩ MAX9000 TOC13 MAX9000 TOC14 MAX9000 TOC15 R RL = 100kΩ L = 10kΩ 120 120 120 RL = 10kΩ 110 110 RL = 2kΩ 110 RL = 10kΩ GAIN (dB) R GAIN (dB) L = 2kΩ GAIN (dB) 100 100 100 RL = 1kΩ 90 90 V V DD = 5.5V DD = 2.5V 90 R R L TO VDD/2 L TO GND VOUT SWING = 0.2V TO 5.3V 80 80 80 0 100 200 300 400 500 600 0 100 200 300 400 500 600 -40 -20 0 20 40 60 80 100 OUTPUT VOLTAGE FROM EITHER SUPPLY (mV) OUTPUT VOLTAGE FROM EITHER SUPPLY (mV) TEMPERATURE (°C)
140 140 140 R VDD = 2.7V L = 100kΩ RL TO VDD 130 130 RL = 100kΩ MAX9000 TOC16 MAX9000 TOC17 MAX9000 TOC18 130 RL = 10kΩ R 120 L = 10kΩ 120 RL = 100kΩ RL = 2kΩ 110 120 RL = 10kΩ 110 RL = 1kΩ GAIN (dB) GAIN (dB) GAIN (dB) 100 R 100 L = 2kΩ 110 V 90 DD = 2.5V V 90 DD = 5.5V RL TO VDD/2 RL TO VDD VOUT SWING = 0.2V TO 2.3V 80 100 80 0 100 200 300 400 500 600 0 100 200 300 400 500 600 -40 -20 0 20 40 60 80 100 OUTPUT VOLTAGE FROM EITHER SUPPLY (mV) OUTPUT VOLTAGE FROM EITHER SUPPLY (mV) TEMPERATURE (°C)
6 _______________________________________________________________________________________
