Datasheet MAX9000, MAX9001, MAX9002, MAX9003, MAX9004, MAX9005 (Analog Devices) - 7
Description | Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs |
Pages / Page | 20 / 7 — Low-Power, High-Speed, Single-Supply. Op Amp + Comparator + Reference … |
File Format / Size | PDF / 255 Kb |
Low-Power, High-Speed, Single-Supply. Op Amp + Comparator + Reference ICs. MAX9000–MAX9005
Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs MAX9000–MAX9005 _____________________________Typical Operating Characteristics (continued)
(VDD = +5V, VSS = 0, VCM (op amp) = 0, SHDN = VDD, COUT = low, RL = ∞, TA = +25°C, unless otherwise noted.)
MAX9000/MAX9001/MAX9002 MAX9000/MAX9001/MAX9002 MAX9000/MAX9001/MAX9002 OP-AMP GAIN AND PHASE OP-AMP GAIN AND PHASE OP-AMP POWER-SUPPLY REJECTION vs. FREQUENCY (NO LOAD) vs. FREQUENCY (WITH CLOAD) vs. FREQUENCY
MAX9000 TOC 19 60 180 60 MAX9000 TOC20 180 0 144 AV = +1 A 144 V = +1000 AV = +1000 NO LOAD 40 NO LOAD 108 40 CL = 270pF 108 -20 MAX9000 TOC21 GAIN 72 GAIN 72 20 36 20 36 -40 0 0 GAIN (dB) GAIN (dB) 0 -36 0 -36 -60 PHASE (DEGREES) PHASE (DEGREES) PHASE -72 PHASE -72 -20 -108 -20 -108 POWER-SUPPLY REJECTION (dB) -80 -144 -144 -40 -180 -40 -180 -100 100 1k 10k 100k 1M 10M 100 1k 10k 100k 1M 10M 100 1k 10k 100k 1M 10M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz)
MAX9003/MAX9004/MAX9005 MAX9003/MAX9004/MAX9005 MAX9003/MAX9004/MAX9005 OP-AMP GAIN AND PHASE OP-AMP GAIN AND PHASE OP-AMP POWER-SUPPLY REJECTION vs. FREQUENCY (NO LOAD) vs. FREQUENCY (WITH CLOAD) vs. FREQUENCY
MAX9000 TOC23 60 MAX9000 TOC22 180 60 180 0 A A V = +1000 V = +1000 A 144 144 V = +10 NO LOAD CL = 270pF NO LOAD 40 108 108 GAIN 40 GAIN -20 MAX9000 TOC24 72 72 20 36 20 36 -40 0 0 GAIN (dB) GAIN (dB) 0 -36 0 -36 -60 PHASE (DEGREES) PHASE (DEGREES) PHASE -72 PHASE -72 -20 -108 -20 -108 POWER-SUPPLY REJECTION (dB) -80 -144 -144 -40 -180 -40 -180 -100 100 1k 10k 100k 1M 10M 100 1k 10k 100k 1M 10M 100 1k 10k 100k 1M 10M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz)
MAX9000/MAX9001/MAX9002 MAX9003/MAX9004/MAX9005 OP-AMP PERCENT OVERSHOOT OP-AMP PERCENT OVERSHOOT OP-AMP VOLTAGE NOISE DENSITY vs. LOAD CAPACITANCE vs. LOAD CAPACITANCE vs. FREQUENCY
50 50 1000 AV = +1 AV = +10 RL TO VDD/2 R R L = 100kΩ L TO VDD/2 RL = 10kΩ 40 MAX9000 TOC25 40 MAX9000 TOC26 MAX9000 TOC27 RL = 100kΩ √Hz) 300 30 30 RL = 1kΩ 100 RL = 10kΩ 20 20 OVERSHOOT (%) OVERSHOOT (%) VOLTAGE NOISE (nV/ R 30 10 10 L = 1kΩ 0 0 10 0 100 200 300 400 500 600 700 800 900 1000 0 100 200 300 400 500 600 700 800 900 1000 1 10 100 1k 10k 100k CLOAD (pF) CLOAD (pF) FREQUENCY (Hz)
_______________________________________________________________________________________ 7
