Datasheet MAX9000, MAX9001, MAX9002, MAX9003, MAX9004, MAX9005 (Analog Devices) - 9
Description | Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs |
Pages / Page | 20 / 9 — Low-Power, High-Speed, Single-Supply. Op Amp + Comparator + Reference … |
File Format / Size | PDF / 255 Kb |
Low-Power, High-Speed, Single-Supply. Op Amp + Comparator + Reference ICs. MAX9000–MAX9005
Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs MAX9000–MAX9005 _____________________________Typical Operating Characteristics (continued)
(VDD = +5V, VSS = 0, VCM (op amp) = 0, SHDN = VDD, COUT = low, RL = ∞, TA = +25°C, unless otherwise noted.)
COMPARATOR HYSTERESIS COMPARATOR OUTPUT VOLTAGE COMPARATOR OUTPUT VOLTAGE vs. TEMPERATURE SWING HIGH (VOH) vs. SOURCE CURRENT SWING LOW (VOL) vs. SINK CURRENT
3.5 600 600 500 500 3.2 MAX9000 TOC37 MAX9000 TOC38 MAX9000 TOC39 TA = +85°C TA = +85°C 400 400 TA = +25°C 2.9 (mV) TA = +25°C OH (mV) 300 300 - V OL V 2.6 DD HYSTERESIS (mV) V 200 200 TA = -40°C T 2.3 A = -40°C 100 100 2.0 0 0 -40 -20 0 20 40 60 80 100 0 1 2 3 4 5 6 7 8 9 10 0 1 2 3 4 5 6 7 8 9 10 TEMPERATURE (°C) SOURCE CURRENT (mA) SINK CURRENT (mA)
COMPARATOR PROPAGATION DELAY POSITIVE COMPARATOR PROPAGATION NEGATIVE COMPARATOR PROPAGATION vs. INPUT OVERDRIVE DELAY (tPD+) vs. LOAD CAPACITANCE DELAY (tPD-) vs. LOAD CAPACITANCE
300 800 800 700 700 275 t OVERDRIVE = 5mV MAX9000 TOC40 PD- MAX9000 TOC41 OVERDRIVE = 5mV MAX9000 TOC42 600 600 250 OVERDRIVE = 25mV 500 500 OVERDRIVE = 25mV (ns) 225 - (ns) t PD+ 400 t PD OVERDRIVE = 100mV 400 200 t OVERDRIVE = 100mV PD+ 300 300 PROPAGATION DELAY (ns) 175 200 200 150 100 100 0 10 20 30 40 50 60 70 80 90 100 0 2000 4000 6000 8000 10,000 0 2000 4000 6000 8000 10,000 INPUT OVERDRIVE (mV) CLOAD (pF) CLOAD (pF)
COMPARATOR PROPAGATION DELAY VREF POWER-SUPPLY REJECTION VREF OUTPUT VOLTAGE CHANGE vs. TEMPERATURE vs. FREQUENCY vs. TEMPERATURE
200 0 1.0 OVERDRIVE VOLTAGE = 50mV tPD- 0.5 MAX9000 TOC43 -20 MAX9000 TOC44 MAX9000TOC45 175 tPD+ 0 -40 150 -0.5 -60 -1.0 PROPAGATION DELAY (ns) 125 OUTPUT VOLTAGE CHANGE (mV) POWER-SUPPLY REJECTION (dB) -80 -1.5 V REF 100 -100 -2.0 -40 -20 0 20 40 60 80 100 1 10 100 1k 10k 100k 1M -40 -20 0 20 40 60 80 100 TEMPERATURE (°C) FREQUENCY (Hz) TEMPERATURE (°C)
_______________________________________________________________________________________ 9
