Datasheet MAX9000, MAX9001, MAX9002, MAX9003, MAX9004, MAX9005 (Analog Devices) - 10
Description | Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs |
Pages / Page | 20 / 10 — Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs |
File Format / Size | PDF / 255 Kb |
Low-Power, High-Speed, Single-Supply Op Amp + Comparator + Reference ICs _____________________________Typical Operating Characteristics (continued)
(VDD = +5V, VSS = 0, VCM (op amp) = 0, SHDN = VDD, COUT = low, RL = ∞, TA = +25°C, unless otherwise noted.)
VREF OUTPUT VOLTAGE CHANGE VREF OUTPUT VOLTAGE CHANGE vs. LOAD CURRENT vs. SUPPLY VOLTAGE VREF LOAD-TRANSIENT RESPONSE
4 100 +1mA 3 µV) MAX9000 TOC46 MAX9000 TOC47 IOUT -1mA MAX9000-TOC48 50 2mA/div 2 SINKING 1 0 VREF SOURCING 200mV/div 0 OUTPUT VOLTAGE CHANGE (mV) OUTPUT VOLTAGE CHANGE ( -50 -1 V REF V REF -2 -100
MAX9000–MAX9005
-2.0 -1.5 -1.0 -0.5 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 50µs/div LOAD CURRENT (mA) SUPPLY VOLTAGE (V)
V V REF LINE-TRANSIENT RESPONSE REF 0.1Hz to 10Hz VOLTAGE NOISE COMPARATOR PROPAGATION DELAY
MAX9000-TOC51 5.0V VIN- = GND VDD NO LOAD +50mW 500mV/div V 4.5V IN+ MAX9000-TOC49 MAX9000-TOC50 50mV/div -50mW 5µV/div VREF VOUT 100mV/div 2V/div tPD+ tPD- 5µs/div 1sec/div 100ns/div
MAX9000/MAX9001/MAX9002 MAX9000/MAX9001/MAX9002 OP-AMP SMALL-SIGNAL TRANSIENT MAX9003/MAX9004/MAX9005 OP-AMP SMALL-SIGNAL TRANSIENT RESPONSE RESPONSE WITH CLOAD OP-AMP SMALL-SIGNAL TRANSIENT RESPONSE
AV = +1 AV = +1 AV = +10 NO LOAD C V L = 270pF IN NO LOAD V 10mV/div IN MAX9000-TOC52 VIN MAX9000-TOC53 MAX9000-TOC54 50mV/div 50mV/div VOUT 50mV/div VOUT VOUT 50mV/div 50mV/div 500ns/div 1µs/div 500ns/div
10 ______________________________________________________________________________________
