Datasheet TL431, TL431A (Fairchild) - 10
Manufacturer | Fairchild |
Description | Programmable Shunt Regulator |
Pages / Page | 10 / 10 — TL431/TL431A. Ordering Information. Product Number. Output Voltage … |
File Format / Size | PDF / 100 Kb |
TL431/TL431A. Ordering Information. Product Number. Output Voltage Tolerance. Package. Operating Temperature. DISCLAIMER
TL431/TL431A Ordering Information Product Number Output Voltage Tolerance Package Operating Temperature
TL431ACLP TO-92 1% TL431ACD 8-SOP TL431CLP TO-92 -25 ~ + 85oC TL431CP 2% 8-DIP TL431CD 8-SOP
DISCLAIMER
FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS.
LIFE SUPPORT POLICY
FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF THE PRESIDENT OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems 2. A critical component in any component of a life support which, (a) are intended for surgical implant into the body, device or system whose failure to perform can be or (b) support or sustain life, and (c) whose failure to reasonably expected to cause the failure of the life support perform when properly used in accordance with device or system, or to affect its safety or effectiveness. instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. www.fairchildsemi.com 2/22/11 0.0m 001 Stock#DS400301 © 2011 Fairchild Semiconductor Corporation
