MOC306xDESCRIPTION The MOC306x Series are optically coupled isolators consisting of a Gallium Arsenide infrared emitting diode 1 Anode coupled with a monolithic silicon detector performing the functions of a zero crossing bilateral triac 2 Cathode mounted in a standard 6 pin dual-in-line package. 3 NC FEATURES 4 Main Terminal 1 • Zero Voltage Crossing 5 Substrate, • Triac Driver Output (Do not Connect) • High V DRM minimum 600V 6 Main Terminal 2 • High Critical Rate of Rise of Off-State Voltage dv/dt minimum 600V/μs • Isolation Voltage 5000V RMSABSOLUTE MAXIMUM RATINGS • RoHS Compliant TA = 25°C unless otherwise specified. • UL File No. E91231 Package System “TT” Stresses exceeding the absolute maximum ratings can cause • VDE File No. 40028086 permanent damage to the device.Exposure to absolute maximum ratings for long periods of time can adversely affect reliability.APPLICATIONSInput • Solenoid / Valve Controls • Light Controls Forward Current 50mA • AC Motor Drivers Reverse Voltage 6V • Temperature Controls Juntion Temperature 125°C • AC Motor Starters Power dissipation 120mW • Solid State Relays OutputORDER INFORMATION Off State Output Terminal Voltage 600V • Add Suffix “X” for VDE Approval On State RMS Current 100mA • RMS Add G after PN for 10mm lead spacing • Peak Repetitive Surge Current 1.0A Add SM after PN for Surface Mount (Pulse Width 100μs, 120pps) • Add SMT&R after PN for Surface Mount Junction Temperature 125°C Tape & Reel Power Dissipation 150mW Total Package Isolation Voltage 5000VRMS Total Power Dissipation 250mW Operating Temperature -40 to 100°C Storage Temperature -55 to 150°C Lead Soldering Temperature (10s) 260°C ISOCOM COMPONENTS 2004 LTDISOCOM COMPONENTS ASIA LTD Unit 25B, Park View Road West, Park View Industrial Estate Hong Kong Office, Hartlepool, Cleveland, TS25 1PE, United Kingdom Block A, 8/F, Wah Hing Industrial mansion, Tel: +44 (0)1429 863 609 Fax : +44 (0)1429 863 581 36 Tai Yau Street, San Po Kong, Kowloon, Hong Kong. e-mail: sales@isocom.co.uk Tel: +852 2995 9217 Fax : +852 8161 6292 http://www.isocom.com e-mail sales@isocom.com.hk 1 05/02/2018 DD93230
