Datasheet MOC3060, MOC3061, MOC3062, MOC3063 (Isocom) - 2
Manufacturer | Isocom |
Description | Zero Crossing Triac Output, 6 Pin |
Pages / Page | 11 / 2 — MOC306x. ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise … |
File Format / Size | PDF / 3.2 Mb |
MOC306x. ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified). INPUT. Parameter. Symbol. Test Condition. Min. Typ. Max. Unit
MOC306x ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified) INPUT Parameter Symbol Test Condition Min Typ. Max Unit
Forward Voltage V
F IF = 20mA 1.2 1.4 V
Reverse Current IR VR = 6V 0.05 10 μA
OUTPUT Parameter Symbol Test Condition Min Typ. Max Unit
Peak Off-state Current IDRM VDRM = 600V 500 nA
Either Direction IF = 0mA
Note 1
Peak Blocking Voltage VDRM IDRM = 500nA 600 V
Either Direction
On-state Voltage VTM ITM = 100mA (peak) 3.0 V
Either Direction
Critical Rate of dv/dt I 1000 V/μs
F = 0mA, Rise of Off-state Vin = 240VRMS
Voltage
(Static dv/dt)
COUPLED Parameter Symbol Test Condition Min Typ. Max Unit
Input Trigger Current I mA
FT VTM = 3V Either Direction
Note 2
MOC3060 30
MOC3061 15
MOC3062 10
MOC3063 5
Holding Current IH 400 μA Either Direction 2 05/02/2018 DD93230
