Datasheet MPM (Vishay)
ManufacturerVishay
DescriptionMolded, SOT-23 Thin Film Resistor, Surface Mount Divider Network
Pages / Page4 / 1 — MPM (Divider). Molded, SOT-23 Thin Film Resistor, Surface Mount Divider …
File Format / SizePDF / 108 Kb
MPM (Divider). Molded, SOT-23 Thin Film Resistor, Surface Mount Divider Network. FEATURES. Note. LINKS TO ADDITIONAL RESOURCES
Datasheet MPM Vishay
MPM (Divider)
www.vishay.com Vishay Dale Thin Film
Molded, SOT-23 Thin Film Resistor, Surface Mount Divider Network FEATURES
• Excellent long term ratio stability (ΔR ± 0.015 %, 2000 h, +70 °C) • Ratio tolerances to ± 0.01 % • Low TCR tracking ± 2 ppm Available • Zero ohm jumper option available • Standard JEDEC® TO-236 package variation AB • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912
Note LINKS TO ADDITIONAL RESOURCES
* This datasheet provides information about parts that are RoHS-compliant and / or parts that are non RoHS-compliant. For example, parts with lead (Pb) terminations are not RoHS-compliant.
Footprints Packages
Please see the information / tables in this datasheet for details Vishay Dale Thin Film MPM Series Dividers provide
TYPICAL PERFORMANCE
± 2 ppm/°C tracking and a ratio tolerance as tight as 0.01 %,
ABSOLUTE TRACKING
small size, and exceptional stability for all surface mount applications. The standard SOT-23 package format with
TCR 25 2
unity and common standard resistance divider ratios
ABSOLUTE RATIO
provide easy selection for most applications requiring matched pair resistor elements. The ratios listed are
TOL. 0.1 0.05
available for off the shelf delivery. Ratios not listed but within
Note
the datasheet limits are available without NRE charge. See • Typical performance TCR and tolerance does not apply to zero “Global Part Number Information” table for guidance how to ohm jumper create part number for ordering.
SCHEMATIC
3 R R 1 2 1 2
STANDARD DIVIDER RATIOS
(R2/R1)
COMMONLY STOCKED BY DISTRIBUTORS RATIO R2 (
Ω
) R1 (
Ω
) RATIO R2 (
Ω
) R1 (
Ω
100:1 100K 1K 2:1 10K 5K 50:1 50K 1K 2:1 2K 1K 25:1 25K 1K 1:1 100K 100K 20:1 20K 1K 1:1 50K 50K 10:1 20K 2K 1:1 25K 25K 10:1 10K 1K 1:1 10K 10K 9:1 9K 1K 1:1 5K 5K 9:1 900 100 1:1 2.5K 2.5K 6:1 6K 1K 1:1 2K 2K 5:1 10K 2K 1:1 1K 1K 5:1 5K 1K 1:1 500 500 4:1 8K 2K 1:1 250 250 4:1 4K 1K 1:2 5K 10K 3:1 7.5K 2.5K 1:2.5 10K 25K 2:1 50K 25K 1:4 7.5K 30K 2:1 12K 6K 1:9 10K 90K Revision: 03-Jan-2022
1
Document Number: 60001 For technical questions, contact: thinfilm@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
