MPM (Divider) www.vishay.com Vishay Dale Thin Film STANDARD ELECTRICAL SPECIFICATIONS TESTSPECIFICATIONSCONDITIONSMaterial Passivated nichrome - Pin/Lead Number 3 - Resistance Range 250 Ω to 100 kΩ per resistor - Resistance for Jumper ≤ 50 mΩ - TCR: Absolute ± 25 ppm/°C -55 °C to +125 °C TCR: Tracking ± 2 ppm/°C (typical) -55 °C to +125 °C Tolerance: Absolute ± 0.05 % to ± 1.0 % +25 °C Tolerance: Ratio ± 0.01 % to 0.5 % +25 °C Power Rating: Resistor 100 mW Maximum at +70 °C Power Rating: Package 200 mW Maximum at +70 °C Stability: Absolute ΔR ± 0.05 % 2000 h at +70 °C Stability: Ratio ΔR ± 0.015 % 2000 h at +70 °C Voltage Coefficient 0.1 ppm/V - Working Voltage 100 V max. not to exceed P x R - Operating Temperature Range -55 °C to +125 °C - Storage Temperature Range -55 °C to +150 °C - Noise < -30 dB - Thermal EMF 0.2 μV/°C - Shelf Life Stability: Absolute ΔR ± 0.01 % 1 year at +25 °C Shelf Life Stability: Ratio ΔR ± 0.002 % 1 year at +25 °C Note • TCR and TCR tracking are not available for parts with zero ohm jumpers DIMENSIONS AND IMPRINTING in inches and millimeters INCHESMILLIMETERSDIMENSIONMIN.MAX.MIN.MAX.3 A 0.031 0.040 0.79 1.02 W A1 0.001 0.004 0.02 0.10 B 0.105 0.120 2.67 3.05 B T S 0.071 0.079 1.80 2.00 W 0.015 0.021 0.38 0.54 A H L L 0.083 0.098 2.10 2.50 H 0.047 0.055 1.20 1.40 S A1 K J T 0.005 0.010 0.13 0.25 21 Pin # Ø J 0.0035 0.0059 0.089 0.15 K 0.017 0.022 0.44 0.55 Ø 0 8° 0 8° MECHANICAL SPECIFICATIONSDERATING CURVEResistive Element Passivated nichrome 100 10000 Substrate Material Silicon 100 % = 0.2 W Body Molded epoxy Terminals Copper alloy 80 Lead (Pb)-free Option 100 % matte tin ) 1000 Tin Lead Option Sn85 r (% 60 e Tin Lead and Lead (Pb)-free Finish Plated e ne ine w lin o 1st li 2nd l 40 2nd ted P a 100 R 20 0 10 0 70 125 150 Ambient Temperature (°C) Revision: 03-Jan-2022 2 Document Number: 60001 For technical questions, contact: thinfilm@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
