Datasheet NCP1729 (ON Semiconductor) - 7
ManufacturerON Semiconductor
DescriptionSwitched Capacitor Voltage Inverter
Pages / Page22 / 7 — NCP1729. Figure 18. Voltage Inverter. Figure 19. Voltage Inverter Load …
File Format / SizePDF / 181 Kb
NCP1729. Figure 18. Voltage Inverter. Figure 19. Voltage Inverter Load Regulation,. Output Voltage vs. Output Current
NCP1729 Figure 18 Voltage Inverter Figure 19 Voltage Inverter Load Regulation, Output Voltage vs Output Current
NCP1729
−Vout 1 6 OSC + Vin 2 5 + + 3 4 Capacitors = 3.3 F
The NCP1729 primary function is a voltage inverter. The device will convert 5.0 V into −5.0 V with light loads. Two capacitors are required for the inverter to function. A third capacitor, the input bypass capacitor, may be required depending on the power source for the inverter. The performance for this device is illustrated below. 0 TA = 25°C −1.0 AGE (V) −2.0 Vin = 3.3 V T −3.0 Vin = 5.0 V −4.0 , OUTPUT VOL outV −5.0 −6.0 0 10 20 30 40 50 Iout, OUTPUT CURRENT (mA)
Figure 19. Voltage Inverter Load Regulation, Output Voltage vs. Output Current http://onsemi.com 7
