Datasheet NCP1729 (ON Semiconductor) - 8
ManufacturerON Semiconductor
DescriptionSwitched Capacitor Voltage Inverter
Pages / Page22 / 8 — NCP1729. Figure 20. Cascaded Devices for Increased Negative Output …
File Format / SizePDF / 181 Kb
NCP1729. Figure 20. Cascaded Devices for Increased Negative Output Voltage. Curve. Vin (V). Rout (
NCP1729 Figure 20 Cascaded Devices for Increased Negative Output Voltage Curve Vin (V) Rout (
NCP1729
Vin −Vout 1 6 1 6 OSC OSC + + + 2 5 2 5 + + 3 4 3 4 Capacitors = 3.3 F
Two or more devices can be cascaded for increased output voltage. Under light load conditions, the output voltage is approximately equal to −Vin times the number of stages. The converter output resistance increases dramatically with each additional stage. This is due to a reduction of input voltage to each successive stage as the converter output is loaded. Note that the ground connection for each successive stage must connect to the negative output of the previous stage. The performance characteristics for a converter consisting of two cascaded devices are shown below. −1.0 −2.0 −3.0 B AGE (V) −4.0 T −5.0 −6.0 A −7.0
Curve Vin (V) Rout ( )
, OUTPUT VOL −8.0 A 5.0 145 outV −9.0 TA = 25°C B 3.0 180 −10.00 10 20 30 40 Iout, OUTPUT CURRENT (mA)
Figure 21. Cascade Load Regulation, Output Voltage vs. Output Current http://onsemi.com 8
