Datasheet TLV9161, TLV9162, TLV9164 (Texas Instruments) - 7
Manufacturer | Texas Instruments |
Description | TLV916x 16V, 11MHz, Rail-to-Rail Input/Output, Low Offset Voltage, Low Noise Op Amp |
Pages / Page | 69 / 7 — TLV9161,. TLV9162, TL. V9164. www.ti.com. 5 Specifications 5.1 Absolute … |
File Format / Size | PDF / 4.7 Mb |
TLV9161,. TLV9162, TL. V9164. www.ti.com. 5 Specifications 5.1 Absolute Maximum Ratings. MIN. MAX. UNIT. 5.2 ESD Ratings. VALUE
link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7
TLV9161, TLV9162, TL V9164 www.ti.com
SBOSA68D – NOVEMBER 2021 – REVISED MARCH 2024
over operating ambient temperature range (unless otherwise noted)(1)
MIN MAX UNIT
Supply voltage, VS = (V+) – (V–) 0 20 V Common-mode voltage(3) (V–) – 0.5 (V+) + 0.5 V Signal input pins Differential voltage(3) VS + 0.2 V Current(3) –10 10 mA Shutdown pin voltage V– V+ Output short-circuit(2) Continuous Operating ambient temperature, TA –55 150 °C Junction temperature, TJ 150 °C Storage temperature, Tstg –65 150 °C (1) Operating the device beyond the ratings listed under Absolute Maximum Ratings will cause permanent damage to the device. These are stress ratings only, based on process and design limitations, and this device has not been designed to function outside the conditions indicated under Recommended Operating Conditions. Exposure to any condition outside Recommended Operating Conditions for extended periods, including absolute-maximum-rated conditions, may affect device reliability and performance. (2) Short-circuit to ground, one amplifier per package. Extended short-circuit current, especially with higher supply voltage, can cause excessive heating and eventual destruction. (3) Input pins are diode-clamped to the power-supply rails. Input signals that may swing more than 0.5 V beyond the supply rails must be current limited to 10 mA or less.
5.2 ESD Ratings VALUE UNIT
Human-body model (HBM), per ANSI/ESDA/JEDEC JS-001(1) ±2500 V(ESD) Electrostatic discharge V Charged-device model (CDM), per ANSI/ESDA/JEDEC JS-002(2) ±1500 (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process.
5.3 Recommended Operating Conditions
MIN MAX UNIT
VS Supply voltage, (V+) – (V–) 2.7 16 V VI Common mode voltage range V– V+ V VIH High level input voltage at shutdown pin (amplifier disabled) (V–) + 1.1 V+ V VIL Low level input voltage at shutdown pin (amplifier enabled) V– (V–) + 0.2 V TA Specified temperature –40 125 °C Copyright © 2024 Texas Instruments Incorporated Submit Document Feedback 7 Product Folder Links: TLV9161 TLV9162 TLV9164 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Pin Configuration and Functions 5 Specifications 5.1 Absolute Maximum Ratings 5.2 ESD Ratings 5.3 Recommended Operating Conditions 5.4 Thermal Information for Single Channel 5.5 Thermal Information for Dual Channel 5.6 Thermal Information for Quad Channel 5.7 Electrical Characteristics 5.8 Typical Characteristics 6 Detailed Description 6.1 Overview 6.2 Functional Block Diagram 6.3 Feature Description 6.3.1 Input Protection Circuitry 6.3.2 EMI Rejection 6.3.3 Thermal Protection 6.3.4 Capacitive Load and Stability 6.3.5 Common-Mode Voltage Range 6.3.6 Phase Reversal Protection 6.3.7 Electrical Overstress 6.3.8 Overload Recovery 6.3.9 Typical Specifications and Distributions 6.3.10 Packages With an Exposed Thermal Pad 6.3.11 Shutdown 6.4 Device Functional Modes 7 Application and Implementation 7.1 Application Information 7.2 Typical Applications 7.2.1 Low-Side Current Measurement 7.2.1.1 Design Requirements 7.2.1.2 Detailed Design Procedure 7.2.1.3 Application Curve 7.2.2 Buffered Multiplexer 7.3 Power Supply Recommendations 7.4 Layout 7.4.1 Layout Guidelines 7.4.2 Layout Example 8 Device and Documentation Support 8.1 Device Support 8.1.1 Development Support 8.1.1.1 TINA-TI™ (Free Software Download) 8.2 Documentation Support 8.2.1 Related Documentation 8.3 Receiving Notification of Documentation Updates 8.4 Support Resources 8.5 Trademarks 8.6 Electrostatic Discharge Caution 8.7 Glossary 9 Revision History 10 Mechanical, Packaging, and Orderable Information
