Datasheet TS7800 (Taiwan Semiconductor) - 4
ManufacturerTaiwan Semiconductor
Description3-Terminal Fixed Positive Voltage Regulator
Pages / Page9 / 4 — TS7810 Electrical Characteristics. Parameter Symbol Test. Conditions Min. …
File Format / SizePDF / 270 Kb
TS7810 Electrical Characteristics. Parameter Symbol Test. Conditions Min. Typ. Max. Unit. TS7812 Electrical Characteristics
TS7810 Electrical Characteristics Parameter Symbol Test Conditions Min Typ Max Unit TS7812 Electrical Characteristics
(Vin=16V, Iout=500mA, 0oC≤Tj≤125oC, Cin=0.33uF, Cout=0.1uF; unless otherwise specified.)
Tj=25oC 9.6 10 10.4 Output Voltage Vout 12.5V≤Vin≤25V, 10mA≤Iout≤1A, 9.5 10 10.5 V PD≤15W 12.5V≤Vin≤28V -- 7 200 Line Regulation REGline Tj=25oC 13V≤Vin≤17V -- 2 100 mV 10mA≤Iout≤1A -- 12 200 Load Regulation REGload Tj=25oC 250mA≤Iout≤750mA -- 4 100 Quiescent Current Iq Iout=0, Tj=25oC -- 4.3 8 12.5V≤Vin≤28V -- -- 1 mA Quiescent Current Change ∆Iq 10mA≤Iout≤1A -- -- 0.5 Output Noise Voltage Vn 10Hz≤f≤100KHz, Tj=25oC -- 70 -- uV Ripple Rejection Ratio RR f=120Hz, 13V≤Vin≤23V 55 71 -- dB Voltage Drop Vdrop Iout=1.0A, Tj=25oC -- 2 -- V Output Resistance Rout f=1KHz -- 18 -- mΩ Output Short Circuit Current Ios Tj=25oC -- 400 -- mA Peak Output Current Io peak Tj=25oC -- 2.2 -- A Temperature Coefficient of mV/ ∆Vout/ ∆Tj Iout=10mA, 0oC≤Tj≤125oC -- -1 -- Output Voltage oC
(Vin=19V, Iout=500mA, 0oC≤Tj≤125oC, Cin=0.33uF, Cout=0.1uF; unless otherwise specified.)
Tj=25oC 11.53 12 12.48 Output Voltage Vout 14.5V≤Vin≤27V, 10mA≤Iout≤1A, 11.42 12 12.60 V PD ≤15W 14.5V≤Vin≤30V -- 10 240 Line Regulation REGline Tj=25oC 15V≤Vin≤19V -- 3 120 mV 10mA≤Iout≤1A -- 12 240 Load Regulation REGload Tj=25oC 250mA≤Iout≤750mA -- 4 120 Quiescent Current Iq Tj=25oC, Iout=0 -- 4.3 8 14.5V≤Vin≤30V -- -- 1 mA Quiescent Current Change ∆Iq 10mA≤Iout≤1A -- -- 0.5 Output Noise Voltage Vn 10Hz≤f≤100KHz, Tj=25oC -- 75 -- uV Ripple Rejection Ratio RR f=120Hz, 15V≤Vin≤25V 55 71 -- dB Voltage Drop Vdrop Iout=1.0A, Tj=25oC -- 2 -- V Output Resistance Rout f=1KHz -- 18 -- mΩ Output Short Circuit Current Ios Tj=25oC -- 350 -- mA Peak Output Current Io peak Tj=25oC -- 2.2 -- A Temperature Coefficient of mV/ ∆Vout/ ∆Tj Iout=10mA, 0oC≤Tj≤125oC -- -1 -- Output Voltage oC z Pulse testing techniques are used to maintain the junction temperature as close to the ambient temperature as possible, and thermal effects must be taken into account separately. z This specification applies only for DC power dissipation permitted by absolute maximum ratings. TS7800 series 4-9 2003/12 rev. A
