Datasheet TS7800 (Taiwan Semiconductor) - 5
ManufacturerTaiwan Semiconductor
Description3-Terminal Fixed Positive Voltage Regulator
Pages / Page9 / 5 — TS7815 Electrical Characteristics. Parameter Symbol Test. Conditions Min. …
File Format / SizePDF / 270 Kb
TS7815 Electrical Characteristics. Parameter Symbol Test. Conditions Min. Typ. Max. Unit. TS7818 Electrical Characteristics
TS7815 Electrical Characteristics Parameter Symbol Test Conditions Min Typ Max Unit TS7818 Electrical Characteristics
(Vin=23V, Iout=500mA, 0oC≤Tj≤125oC, Cin=0.33uF, Cout=0.1uF; unless otherwise specified.)
Tj=25oC 14.42 15 15.60 Output Voltage Vout 17.5V≤Vin≤30V, 10mA≤Iout≤1A, 14.28 15 15.75 V PD ≤15W 17.5V≤Vin≤30V -- 12 300 Line Regulation REGline Tj=25oC 18V≤Vin≤22V -- 3 150 mV 10mA≤Iout≤1A -- 12 300 Load Regulation REGload Tj=25oC 250mA≤Iout≤750mA -- 4 150 Quiescent Current Iq Tj=25oC, Iout=0 -- 4.3 8 17.5V≤Vin≤30V -- -- 1 mA Quiescent Current Change ∆Iq 10mA≤Iout≤1A -- -- 0.5 Output Noise Voltage Vn 10Hz≤f≤100KHz, Tj=25oC -- 90 -- uV Ripple Rejection Ratio RR f=120Hz, 18V≤Vin≤28V 54 70 -- dB Voltage Drop Vdrop Iout=1.0A, Tj=25oC -- 2 -- V Output Resistance Rout f=1KHz -- 19 -- mΩ Output Short Circuit Current Ios Tj=25oC -- 230 -- mA Peak Output Current Io peak Tj=25oC -- 2.2 -- A Temperature Coefficient of mV/ ∆Vout/ ∆Tj Iout=10mA, 0oC≤Tj≤125oC -- -1 -- Output Voltage oC
(Vin=27V, Iout=500mA, 0oC≤Tj≤125oC, Cin=0.33uF, Cout=0.1uF; unless otherwise specified.)
Tj=25oC 17.30 18 18.72 Output Voltage Vout 21V≤Vin≤33V, 10mA≤Iout≤1A, 17.14 18 18.90 V PD ≤15W 21V≤Vin≤33V -- 15 360 Line Regulation REGline Tj=25oC 22V≤Vin≤26V -- 5 180 mV 10mA≤Iout≤1A -- 12 360 Load Regulation REGload Tj=25oC 250mA≤Iout≤750mA -- 4 180 Quiescent Current Iq Tj=25oC, Iout=0 -- 4.5 8 21V≤Vin≤33V -- -- 1 mA Quiescent Current Change ∆Iq 10mA≤Iout≤1A -- -- 0.5 Output Noise Voltage Vn 10Hz≤f≤100KHz, Tj=25oC -- 110 -- uV Ripple Rejection Ratio RR f=120Hz, 21V≤Vin≤31V 54 70 -- dB Voltage Drop Vdrop Iout=1.0A, Tj=25oC -- 2 -- V Output Resistance Rout f=1KHz -- 22 -- mΩ Output Short Circuit Current Ios Tj=25oC -- 200 -- mA Peak Output Current Io peak Tj=25oC -- 2.2 -- A Temperature Coefficient of mV/ ∆Vout/ ∆Tj Iout=10mA, 0oC≤Tj≤125oC -- -1 -- Output Voltage oC z Pulse testing techniques are used to maintain the junction temperature as close to the ambient temperature as possible, and thermal effects must be taken into account separately. z This specification applies only for DC power dissipation permitted by absolute maximum ratings. TS7800 series 5-9 2003/12 rev. A
