Datasheet MM74C74 (Fairchild) - 7
ManufacturerFairchild
DescriptionDual D-Type Flip-Flop
Pages / Page7 / 7 — MM74C74 Dual D-T. Physical Dimensions. y pe Fl. ip- F lop
File Format / SizePDF / 87 Kb
MM74C74 Dual D-T Physical Dimensions y pe Fl ip- F lop
inches (millimeters) unless otherwise noted (Continued)
y pe Fl ip- F lop 14-Lead Plastic Dual-In-Line Package (PDIP), JEDEC MS-001, 0.300" Wide Package Number N14A
Fairchild does not assume any responsibility for use of any circuitry described, no circuit patent licenses are implied and Fairchild reserves the right at any time without notice to change said circuitry and specifications.
LIFE SUPPORT POLICY
FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF THE PRESIDENT OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems 2. A critical component in any component of a life support which, (a) are intended for surgical implant into the device or system whose failure to perform can be rea- body, or (b) support or sustain life, and (c) whose failure sonably expected to cause the failure of the life support to perform when properly used in accordance with device or system, or to affect its safety or effectiveness. instructions for use provided in the labeling, can be rea- sonably expected to result in a significant injury to the
www.fairchildsemi.com
user. 7 www.fairchildsemi.com
