Datasheet V275LA4P (Littelfuse) - 8
ManufacturerLittelfuse
DescriptionMetal-Oxide Varistors
Pages / Page13 / 8 — Metal-Oxide V. istors. Maximum Clamping Voltage for 20mm Parts. …
Metal-Oxide V. istors. Maximum Clamping Voltage for 20mm Parts. V130LA20A(P) - V275LA40A(P). V300LA40A. - V1000LA160B. Figure 14
Metal-Oxide V istors Maximum Clamping Voltage for 20mm Parts V130LA20A(P) - V275LA40A(P) V300LA40A - V1000LA160B Figure 14
3,000 5,000 MAXIMUM CLAMPING VOLTAGE MAXIMUM CLAMPING VOLTAGE MODEL SIZE 14mm V1000LA80A(P) MODEL SIZE 20mm 385 TO 1000VM(AC) RATING 2,000 130 TO 275VM(AC) RATING T V680LA80A(P) T 3,000 A = -55oC TO 85oC A = -55oC TO 85oC V660LA50A(P) S (V) V625LA40A(P) LTS (V) 2,000 LT 1,000 VO VO 900 800 700 1,000 600 V275LA40A(P) 500 700 V250LA40A(P) V175LA20A(P) V575LA40A(P) 400 MAXIMUM PEAK V510LA40A(P) MAXIMUM PEAK 500 300 V480LA40A(P)/V460LA20A(P) V150LA20A(P) V420LA20A(P) V130LA20A(P) V385LA20A(P) 300 200 10-3 10-2 10-1 100 101 102 103 10-4 104 10-3 10-2 10-1 100 101 102 103 104 PEAK AMPERES (A) PEAK AMPERES (A) FIGURE 9. CLAMPING VOLTAGE FOR V385LA20A(P) - FIGURE 10. CLAMPING VOLTAGE FOR V130LA20A(P) - V275LA40A(P) V1000LA80A(P) 3,000 3,000 MAXIMUM CLAMPING VOLTAGE MAXIMUM CLAMPING VOLTAGE MODEL SIZE 20mm MODEL SIZE 20mm 2,000 130 TO 275VM(AC) RATING 140 TO 230VM(AC) RATING T 2,000 A = -55oC TO 85oC TA = -55oC TO 85oC 2,000 5,000 1 MODEL SIZE 7mm 1 MODEL SIZE 10mm 1,000 V130LA5(P) - V680LA10(P) LTS (V) V130LA1(P) - V480LA7(P) 2,000 1,000 2 LTS (V) 2 VO 1,000 900 500 VO 1,000 102 800 15 103 V230LA40A(P) 103
Metal-Oxide V
700 200 104 500 15 104 600 105 V275LA40B(P)
ar
T (A)
istors
102 (MOVs) T (A) 105 100 106 106 200 Radial Lead V 500 500 V250LA40B(P) 400 aristors > LA V 50 aristor Series 100 MAXIMUM PEAK MAXIMUM PEAK V140LA20A(P) 300 V150LA20B(P) 20 300 50 V130LA20B(P) 10 SURGE CURREN 20 SURGE CURREN 200 200 5 INDEFINITE INDEFINITE 10-3 10-2 10-1 100 101 102 103 104 10-3 10-2 10-1 100 101 10 102 103 104 PEAK AMPERES (A) PEAK AMPERES (A) 2 5
FIGURE 11. CLAMPING VOLTAGE FOR V130LA20 1 B(P) - V275LA40(P) FIGURE 12. CLAMPING VOLTAGE FOR V140LA20 2 A(P) - V230LA40A(P) 20 100 1,000 10,000 20 100 1,000 10,000 IMPULSE DURATION (
IMPULSE DURATION ( μs)
V300LA40A
3,000
- V1000LA160B
μs) 5,000 MAXIMUM CLAMPING VOLTAGE MAXIMUM CLAMPING VOLTAGE FIGURE 14. SURGE CURRENT RATING CURVES FOR FIGURE 15. SURGE CURRENT RATING CURVES FOR 3,000 MODEL SIZE 14mm V1000LA80A(P) 5,000MODEL SIZE 20mm 385 TO 1000VM(AC) RATING 2,000 130 TO 275V V1 M(AC) RATING 30LA1(P) - V480LA7(P) V130LA5(P) - V680LA10(P) 5,000 MAXIMUM CLAMPING VOLTAGE MAXIMUM CLAMPING VOLTAGE MAXIMUM CLAMPING VOLTAGE V680LA80A(P) MODEL SIZE 14mm V1000LA80A(P) T MODEL SIZE 20m A = -55oC TO 85oCm T MODEL SIZE 20mm 3,000 A = -55oC TO 85oC 385 TO 1000V 2,000 5,000 300 TO 1000V V1000LA160B(P) M(AC) RATING 2,000 130 TO 275VM(AC) RATING M(AC) RATING 1 MODEL SIZE 7mm MODEL SIZE 10mm T V680LA80A(P) 5,0001 5,000 T V660LA50A(P) S (V) TA = -55oC TO 85oC 3,000 A = -55oC TO 85oC 1,000 A = -55oC TO 85oC V130LA1(P) - V480LA7(P) 3,000 V625LA40A(P) 1 2,000 MODEL SIZE V1 14mm 30LA5(P) - V680LA10(P) 1 MODEL SIZE 14mm LTS (V) 2,000 LT 2 1,000 2 2 V680LA100B(P) V130LA10A(P) - V320LA20A(P) 2 V385LA20A(P) - V1000LA80A(P) V660LA50A(P) 2,000 2,000 S (V) 500 V625LA80B(P) VO VO 900 102 V625LA40A(P) 1,000 V660LA100B(P) LTS (V) 2,000 LT 103 LTS (V)800 15 103 1,000 15 2,000 1,000 102 15 1,000 102 200 104 700 500 15 V575LA80B(P) 103 104 103 VO VO 900 VO 105 104 105 104 T (A) 800 1,000 102 T (A) 600500 V275LA40A(P) 500 100 106 T (A) V510LA80B(P) 105 106 105 700 500 T (A) 200 V480LA80B(P)/ 106 106 1,000 600 700 50 V275LA40A(P) 200 V460LA40B(P) V250LA40A(P) V175LA20A(P) 200 V575LA40A(P) 400 100 500 MAXIMUM PEAK V510LA40A(P) MAXIMUM PEAK 1,000 100 100 700 500 V250LA40A(P) V175LA20A(P) 300 50 V575LA40A(P) 400 20 V480LA40A(P)/V460LA20A(P) V150LA20A(P) V420LA20A(P) 50 50 MAXIMUM PEAK V510LA40A(P) MAXIMUM PEAK MAXIMUM PEAK 500 300 V130LA20A(P) 10 V385LA20A(P) V420LA40B(P) V480LA40A(P)/V460LA20A(P) SURGE CURREN 20 SURGE CURREN V150LA20A(P) V385LA40B(P) V420LA20A(P) 300 SURGE CURREN 20020 SURGE CURREN 20 5 INDEFINITE INDEFINITE V130LA20A(P) V320LA40B(P) V385LA20A(P) 10-3 10-2 10-1 100 101 102 103 10-4 104 10 10 -3 10-2 10-1 INDEFINITE 100 101 102 103 104 INDEFINITE 500 10 V300LA40A(P) 10 300 200 PEAK AMPERES (A) 5 PEAK AMPERES (A) 2 5 10-3 10-2 10-1 100 101 102 103 104 10-3 10-2 10-1 100 101 102 103 10-4 104 10-3 10-2 10-1 100 101 102 103 104 5 PEAK AMPERES (A)
Figure 14
1 PEAK AMPERES (A) PEAK AMPERES (A)
Figure 15
FIGURE 9. CLAMPING VOLTAGE FOR V385LA20A(P) - FIGURE 10 2 . CLAMPING VOLTAGE FOR V130LA20A(P) - V275LA40A(P) 20 100 1,000 10,000 2 20 100 1,000 10,000 2 V1000LA80A(P) 20 100IMPULSE DURA 1,0 TION ( 00 μs) 10,000 20 100 1,000 10,000 FIGURE 9. CLAMPING VOLTAGE FOR V385LA20A IMPULSE DURATION (μs) FIGURE 13. CLAMPING VOLTAGE FOR V300LA40A - V1000LA160B (P) -
V130LA20B(P) - V275LA40(P)
FIGURE 10. CLAMPING VOLTAGE FOR V130LA20A(P) - V275LA40A(P) IMPULSE DURATION (μs) IMPULSE DURATION (μs) V1000LA80A(P) 3,000 MAXIMUM CLAMPING VOLTAGE FIGURE MAXIMUM CLAMPING 14. VO SURGE CURREN LT T AGE RATING CURVES FOR
Repetitiv
FIGURE
e Sur
15.
ge Capability f
SURGE CURRENT
or 20mm P
RATING
arts
CURVES FOR 5,000 3,000 3,000 MODEL SIZE 14mm V1000LA80A(P) MAXIMUM CLAMPING FIGURE 16. SURGE CURRENT RATING CURVES FOR FIGURE 17. SURGE CURRENT RATING CURVES FOR MODEL SIZE 20m V1 m VO 30LA1(P) - LTAGE V480LA7(P) MAXIMUM CLAMPING V1 VO 30LA5(P) - LTAGE V680LA10(P) 385 TO 1000VM(AC) RATING 2,000 MODEL SIZE 20mm 130 TO 275VM(AC) RATING
V130LA20A(P) - V320LA40B(P)
V130LA10A(P) - V320LA20A(P) V385LA20A(P) - V1000LA80A(P) 3,000 MODEL SIZE 20mm T V680LA80A(P) 3,000 MAXIMUM CLAMPING A = -55oC TO 85oC VOLTAGE 2,000 130 T TO 275VC TO 85oC 3,000 5,000 MAXIMUM CLAMPING A = -55o M(AC) RATING VOLTAGE 2,000 140 TO 230VM(AC) RATING 5,000 MODEL SIZE 20mm T MODEL SIZE 20mm A = -55oC TO 85oC 10, T 000 1 A = -55oC TO 85oC 10,000 MODEL SIZE 14mm 11 MODEL SIZE 14mm 1 2,000 130 TO 275VM(AC V660LA50A(P) RATING S (V) 140 2 TO 230V MODEL SIZE 20mm MODEL SIZE 20mm M(AC) RATING V130LA10A(P) - V320LA20A(P) 5,000 2 2 V385LA20A(P) - V1000LA80A(P) 5,000 2 V625LA40A(P) 2,000 2,000 LTS (V) T 2,000 2,000 LT 15 V130LA20A(P) - V320LA40B(P) 15 V385LA40B(P) - V1000LA160B(P) A = -55oC TO 85oC 1,000 TA = -55oC TO 85oC LTS (V) 15 102 102 VO VO 900 2,000 15 2,000 1,000 1,000 102 LTS (V) 1,000 102103 103 VO 800 103 1,000 103 900 104 VO 104 1,000 104 104 1,000 LTS (V) 800 700 500 500 105 105 1,000 LTS (V) 105 V230LA40A(P 105 ) T (A) T (A) VO 1,000 1,000 600 V275LA40A(P) 500 106 500 106 900 106 106 VO 700 T (A) T (A) 800 600 500 200 V275LA40B(P) 200 V230LA40A(P) V250LA40A(P) V175LA20A(P) 200 200 700 700 V575LA40A(P) 500 400 100 500 100 600 100 100 MAXIMUM PEAK V275LA40B(P) V510LA40A(P) MAXIMUM PEAK V250LA40B(P) 500 400 300 500 V480LA40A(P)/V460LA20A(P) MAXIMUM PEAK 50 50 500 V150LA20A(P) 50 50 MAXIMUM PEAK V140LA20A(P) V250LA40B(P) V420LA20A(P) 300 V150LA20B(P) 400 V130LA20A(P) 300 V385LA20A(P) MAXIMUM PEAK SURGE CURREN 20 SURGE CURREN 20 20 20 300 MAXIMUM PEAK 200 V140LA20A(P) INDEFINITE INDEFINITE 300 V150LA20B(P) SURGE CURREN SURGE CURREN INDEFINITE INDEFINITE 300 V130LA20B(P) 10 10 10 10 10-3 10-2 10-1 100 101 102 103 10-4 104 10-3 10-2 10-1 100 101 102 103 104 200 200 PEAK AMPERES (A) 5 PEAK AMPERES (A) 5 5 5 V130LA20B(P) 10-3 10-2 10-1 100 101 102 103 104 10-3 10-2 10-1 100 101 102 103 104 200 200 PEAK AMPERES (A) PEAK AMPERES (A)
Figure 16
2 2 10-3 FIGURE 10 9. -2 10-1 CLAMPING VO 10 LT0 AGE 101 FOR 102 V385LA20A 10 (P)3 - 104 FIGURE 10 2 . 10 C-3 10-2 LAMPING 10 VO -1 LTA 100 GE FOR 101 10 V130LA202A(P) 10 - 3 104 V275LA40A(P) 2 20 100 1,000 10,000 20 100 1,000 10,000 PEAK AMPERES (A) V1000LA80A(P) 1 1
FIGURE 11. CLAMPING PEAK AMPERES (A VOLTAGE FOR ) V130LA20 IMPULSE DURATION (μs) B(P) - V275LA40(P) FIGURE 12. 20 CLAMPING VO 100 LTAGE FOR V140LA20 IMPULSE DURA 1,0 TION ( 00 μs) A(P) - V230LA40 1 A 0, (P) 000 20 100 1,000 10,000
Figure 18
IMPULSE DURATION (μs) IMPULSE DURATION (μs) FIGURE 11. 3,000 CLAMPING VOLTAGE FOR V130LA20B(P) - V275LA40(P) FIGURE 12. FIGURE 16 CLAMPING . VOLTAGE FOR SURGE CURRENT RA V140LA20 TING A(P) - V230LA40 CURVES FOR A(P) 3,000 FIGURE 17. SURGE CURRENT RATING CURVES FOR MAXIMUM CLAMPING VOLTAGE MAXIMUM CLAMPING V130LA1 VOL 0A(P) - TAGE V320LA20A(P)
V385LA40B(P)
FIGURE
- V1
18.
000LA160B(P)
SURGE CURRENT RATING CURVES FOR FIGURE 19. SURGE CURRENT RATING CURVES FOR V385LA20A(P) - V1000LA80A(P) MODEL SIZE 20mm MODEL SIZE 20mm 5,000 V130LA20A(P) - V320LA40B(P) V385LA40B(P) - V1000LA160B(P) 2,000 130 TO 275VM(AC) RATING 140 TO 230V MAXIMUM CLAMPING VOLTAGE M(AC) RATING T 1 2,000 0,000 10,000 A = -55oC TO 85oC 5,000 T MODEL SIZE 20mm A = -55oC TO 85oC 1 1 5,000 2 300 TO MODEL SIZE 20m 1000V m V1000LA160B(P) MODEL SIZE 20mm MAXIMUM CLAMPING VOLTAGE M(AC) RATING 5,000 2 15 V130LA20A(P) - V320LA40B(P) 15 V385LA40B(P) - V1000LA160B(P) MODEL SIZE 20mm T 10 3,000 2 A = -55oC TO 85oC 102 LTS (V) 300 TO 1000V 2,0 V1000LA160B(P) M(AC) RATING 00 2,000 LTS (V) 103 V680LA100B(P) 103 1,000 T 1,000 V625LA80B(P) VO 104 104 900 3,000 A = -55oC TO 85oC VO 1,000 1,000 LTS (V) 105 V660LA100B(P) 105 800 V625LA80B(P) V680LA100B(P) 2,000 500 V230LA40A(P 106 ) 500 106 700 VO V575LA80B(P) T (A) T (A) 600 V275LA40B(P) LTS (V) V660LA100B(P) 2,000 200 V510LA80B(P) 200 500 VO V575LA80B(P) 500 V480LA80B(P)/ 100 100 V250LA40B(P) 400 V510LA80B(P) V460LA40B(P) MAXIMUM PEAK 50 50 V480LA80B(P)/ MAXIMUM PEAK 1,000 V140LA20A(P) 300 V150LA20B(P) V460LA40B(P) 300 20 20 1,000 MAXIMUM PEAK SURGE CURREN INDEFINITE SURGE CURREN V420LA40B(P) INDEFINITE V130LA20B(P) 10 10 V385LA40B(P) 200 MAXIMUM PEAK 200 10-3 10-2 10-1 100 101 102 103 104 5 V420LA40B(P) 5 V320LA40B(P) 10-3 10-2 10-1 100 101 102 103 104 PEAK AMPERES (A)
Figure 17
V385LA40B(P) 500 V300LA40A(P) PEAK AMPERES (A) 2 V320LA40B(P) 2 10-3 10-2 10-1 100 101 102 103 104 500 V300LA40A(P) 1 1 FIGURE 11. CLAMPING VOLTAGE FOR V130LA20B(P) - V275LA40(P)
Note:
If pulse ratings are exceeded, a shift of V FIGURE 12. 20 CLAMPING 10 VO 0 LT (at specified current) of more than +/-10% could result. This PEAK AMPERES (A) AGE FOR V140LA20 1,000 A N(DC) (P) - V230LA40 10,A(P) 10-3 10-2 10-1 000 20 100 1,000 10,000 type of shift, which normally results in a decrease of V 100 101 102 103 104 , may result in the device not meeting the original N(DC) published specifications, but does not prevent the device from continuing to function, and to provide ample PEAK AMPERES (A) IMPULSE DURATION (
Figure 19
FIGURE 13. μs)CLAMPING VOLTAGE FOR V300LA40A - V1000LA160BIMPULSE DURATION (μs) protection. FIGURE 18. SURGE CURRENT RATING CURVES FOR FIGURE 19. SURGE CURRENT RATING CURVES FOR FIGURE 13. 5,000 CLAMPING VOLTAGE FOR V300LA40A - V1000LA160B
Note:
Repetitive surge capability is qualified and tested based on 8/20us current waveform (not combination MAXIMUM CLAMPING VOLTAGE V130LA20A(P) - V320LA40B(P) V385LA40B(P) - V1000LA160B(P) waveform) and UL1449 40.7.3 (Edition 4) test condition. MODEL SIZE 20mm 300 TO 1000V V1000LA160B(P) M(AC) RATING T 3,000 A = -55oC TO 85oC V680LA100B(P) © 2019 Littelfuse, Inc. V625LA80B(P) Specifications are subject to change without notice. LTS (V) V660LA100B(P) 2,000 Revised: 12/17/19 VO V575LA80B(P) V510LA80B(P) V480LA80B(P)/ V460LA40B(P) 1,000 MAXIMUM PEAK V420LA40B(P) V385LA40B(P) V320LA40B(P) 500 V300LA40A(P) 10-3 10-2 10-1 100 101 102 103 104 PEAK AMPERES (A) FIGURE 13. CLAMPING VOLTAGE FOR V300LA40A - V1000LA160B
