Datasheet MAX6701, MAX6701A, MAX6702, MAX6702A, MAX6703, MAX6703A, MAX6704, MAX6705, MAX6705A, MAX6706, MAX6706A, MAX6707, MAX6707A, MAX6708 (Analog Devices) - 10
Description | Low-Voltage, SOT23, µP Supervisors with Power-Fail In/Out, Manual Reset, and Watchdog Timer |
Pages / Page | 12 / 10 — Selector Guide. RESET. RST_IN1,. PART. WDI. WDO. PFI,. PP LOW. PP HIGH. … |
File Format / Size | PDF / 1.2 Mb |
Selector Guide. RESET. RST_IN1,. PART. WDI. WDO. PFI,. PP LOW. PP HIGH. OD-LOW. PFO. RST_IN2. Threshold Suffix Guide. SUFFIX. THRESHOLD (V)
MAX6701-08/ Low-Voltage, SOT23 µP Supervisors with Power-Fail MAX6701A-03A/ In/Out, Manual Reset, and Watchdog Timer MAX6705A-07A 0.9V 3.3V MAX6701(A) MAX6704 MAX6705(A) I/O CORE MAX6708 SUPPLY SUPPLY V RESET CC RESET (RESET) RESET PFI µP MAX6704– MR R1 (100kΩ) MAX6708 PFO () ARE FOR MAX6704/MAX6706(A)/MAX6708 ONLY. Figure 9. RESET Valid to Ground Circuit Figure 10. Monitoring Other System Voltages
Selector Guide RESET RESET RESET RST_IN1, PART WDI WDO PFI, PP LOW PP HIGH OD-LOW PFO RST_IN2
MAX6701 ✔ — — ✔ ✔ PP — ✔ MAX6701A* ✔ — — ✔ ✔ PP — ✔ MAX6702 — ✔ — ✔ ✔ PP — ✔ MAX6702A* — ✔ — ✔ ✔ PP — ✔ MAX6703 — — ✔ ✔ ✔ OD — ✔ MAX6703A* — — ✔ ✔ ✔ OD — ✔ MAX6704 ✔ ✔ — ✔ — ✔ PP — MAX6705 ✔ — — ✔ ✔ PP ✔ PP — MAX6705A* ✔ — — ✔ ✔ PP ✔ PP — MAX6706 — ✔ — ✔ ✔ PP ✔ PP — MAX6706A* — ✔ — ✔ ✔ PP ✔ PP — MAX6707 — — ✔ ✔ ✔ OD ✔ OD — MAX6707A* — — ✔ ✔ ✔ OD ✔ OD — MAX6708 ✔ ✔ — — — ✔ PP — PP = push-pull, OD = open drain. *WDO deasserts when MR is pulled low. See the Standard- vs. A-Version Comparison section for the differences on WDO.
Threshold Suffix Guide SUFFIX RESET THRESHOLD (V) L
4.63 M 4.38 T 3.08
S
2.93
R
2.63
Z
2.32 Y 2.19 Bold indicates standard version. www.maximintegrated.com Maxim Integrated │ 10
