Datasheet LM4040 (Diodes)
Manufacturer | Diodes |
Description | Precision Micropower Shunt Voltage References |
Pages / Page | 16 / 1 — LM4040. PRECISION MICROPOWER SHUNT VOLTAGE REFERENCES. Description. Pin … |
File Format / Size | PDF / 1.6 Mb |
LM4040. PRECISION MICROPOWER SHUNT VOLTAGE REFERENCES. Description. Pin Assignments. (Top View). SOT23. Features. SC70-5
LM4040 PRECISION MICROPOWER SHUNT VOLTAGE REFERENCES Description Pin Assignments
The LM4040 is a family of bandgap circuits designed to achieve precision micro-power voltage references of 2.5V, 3.0V, 3.3V, 4.096V,
(Top View)
and 5.0V. The devices are available in 0.2% B-grade, 0.5% C-grade, and 1% D-grade initial tolerances. They are available in smal outline SOT23 surface mount packages, which are ideal for applications where space is at a premium. Excellent performance is maintained over the 60µA to 15mA operating current range with a typical temperature coefficient of only 20ppm/°C. The device is designed to be highly tolerant of capacitive * Pin 3 must be left floating or connected to pin 2 loads, which maintains excellent stability.
SOT23
This device offers a pin for pin compatible alternative to the LM4040 voltage reference. LM4040 H5 (SC70-5)
(Top View) Features
Anode 1 4 N/C • Small Package: SOT23 SC70-5 Variants Are End of Life (EOL) * 2 • No Output Capacitor Required • Output Voltage Tolerance Cathode 3 5 N/C LM4040B: ±0.2% at +25°C Top View LM4040C : ±0.5% at +25°C
SC70-5
** * Pin 2 must be left floating or connected to pi n 1 LM4040D: ±1% at +25°C * Pin 2 must be left floating or connected to pin 1. • Low Output Noise ** SC70-5 variants are End of Life (EOL). • (10Hz to 10kHz) 45µVRMS • Wide Operating Current Range 60µA to 15mA • Extended Temperature Range -40°C to +125°C • Low Temperature Coefficient 100 ppm/°C (max) • Green Molding in Small Package SOT23 •
Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
Halogen and Antimony Free. “Green” Device (Note 3)
An Automotive-Compliant Part is Available Under Separate Datasheet (LM4040Q) Applications
• Battery Powered Equipment • Precision Power Supplies • Portable Instrumentation • Portable Communications Devices • Notebook and Palmtop Computers • Data Acquisition Systems Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. LM4040 1 of 16 August 2019 Document number: DS33195 Rev. 8 - 2
www.diodes.com
© Diodes Incorporated Document Outline Printed Circuit Board Layout Considerations
