Datasheet ISL60002DIH326 (Renesas) - 9
ManufacturerRenesas
DescriptionPrecision Low Power FGA Voltage References
Pages / Page40 / 9 — link. to. page. 9. link. to. page. 9. link. to. page. 9. link. to. page. …
link. to. page. 9. link. to. page. 9. link. to. page. 9. link. to. page. 9. link. to. page. 9. link. to. page. 9. ISL60002. Common. Electrical. Specifications. ISL60002. -10,
link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 ISL60002 Common Electrical Specifications ISL60002 -10,
link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 ISL60002 Common Electrical Specifications ISL60002 -10, -11, -12, -18, -20, and -25 Operating conditions: VIN = 3.0V, IOUT = 0mA, COUT = 0.001µF, TA = -40 to +85°C, unless otherwise specified. Boldface limits apply across the operating temperature range, -40°C to +85°C. MIN MAX PARAMETER SYMBOL TEST CONDITIONS (Note 11) TYP (Note 11) UNIT Output Voltage Temperature Coefficient TC VOUT 20 ppm/°C (Note 12) Supply Current IIN 350 900 nA Line Regulation ΔVOUT/ΔVIN +2.7V ≤ VIN ≤ +5.5V 80 250 µV/V Load Regulation ΔVOUT/ΔIOUT 0mA ≤ ISOURCE ≤ 7mA 25 100 µV/mA -7mA ≤ ISINK ≤ 0mA 50 150 µV/mA Thermal Hysteresis (Note 13) ΔVOUT/ΔTA ΔTA = +125°C 100 ppm Long Term Stability (Note 14) ΔVOUT/Δt TA = +25°C; first 1khrs 50 ppm Short-Circuit Current (to GND) (Note 15) ISC TA = +25°C 50 mA Output Voltage Noise VN 0.1Hz ≤ f ≤ 10Hz 30 µVP-P NOTES: 11. Compliance to datasheet limits is assured by one or more methods: production test, characterization, and/or design. 12. Across the specified temperature range. Temperature coefficient is measured by the box method where the change in VOUT is divided by the temperature range: (-40°C to +85°C = +125°C, or -40°C to +105°C = +145°C for the ISL60002-33). 13. Thermal hysteresis is the change in VOUT measured at TA = +25°C after temperature cycling over a specified range, ΔTA, VOUT is read initially at TA = +25°C for the device under test. The device is temperature cycled and a second VOUT measurement is taken at +25°C. The difference between the initial VOUT reading and the second VOUT reading is then expressed in ppm. For ΔTA = +125°C, the device under test is cycled from +25°C to +85°C to -40°C to +25°C, and for ΔTA = +145°C, the device under test is cycled from +25°C to +105°C to -40°C to +25°C. 14. Long term drift is logarithmic in nature and diminishes over time. Drift after the first 1000 hours is approximately 10ppm. 15. Short-circuit current (to VCC) for ISL60002-25 at VIN = 5.0V and +25°C is typically around 30mA. Shorting VOUT to VCC is not recommended due to risk of resetting the part. FN8082 Rev.23.01 Page 9 of 40 Oct 16, 2019 Document Outline Applications Features Related Literature Table of Contents Pin Configuration Pin Descriptions Ordering Information Absolute Maximum Ratings Thermal Information Environmental Operating Conditions Recommended Operating Conditions Electrical Specifications ISL60002-10, VOUT = 1.024V Electrical Specifications ISL60002-11, VOUT = 1.200V Electrical Specifications ISL60002-12, VOUT = 1.250V Electrical Specifications ISL60002-18, VOUT = 1.800V Electrical Specifications ISL60002-20, VOUT = 2.048V Electrical Specifications ISL60002-25, VOUT = 2.500V Electrical Specifications ISL60002-26, VOUT = 2.600V Electrical Specifications ISL60002-30, VOUT = 3.000V Electrical Specifications ISL60002-33, VOUT = 3.300V Common Electrical Specifications ISL60002 -10, -11, -12, -18, -20, and -25 Typical Performance Characteristic Curves, VOUT = 1.024V Typical Performance Characteristic Curves, VOUT = 1.20V Typical Performance Characteristic Curves, VOUT = 1.25V Typical Performance Curves, VOUT = 1.8V Typical Performance Curves, VOUT = 2.048V Typical Performance Characteristic Curves, VOUT = 2.50V Typical Performance Characteristic Curves, VOUT = 3.0V Typical Performance Characteristic Curves, VOUT = 3.3V High Current Application Applications Information FGA Technology Nanopower Operation Board Mounting Considerations Board Assembly Considerations Special Applications Considerations Noise Performance and Reduction Turn-On Time Temperature Coefficient Typical Application Circuits Revision History Package Outline Drawing
