Datasheet MAX6061, MAX6062, MAX6063, MAX6064, MAX6065, MAX6066, MAX6067, MAX6068 (Analog Devices) - 6
DescriptionPrecision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage References
Pages / Page16 / 6 — Precision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage …
File Format / SizePDF / 559 Kb
Precision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage References ELECTRICAL CHARACTERISTICS—MAX6063, VOUT = 3.0V
(VIN = +5V, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX6063A (0.2%) 2.994 3.000 3.006 Output Voltage VOUT TA = +25°C V Output Voltage MAX6063B (0.4%) 2.988 3.000 3.012 MAX6063A 6 20 Output Voltage Temperature TCVOUT ppm/°C Coefficient (Note 2) MAX6063B 6 30 ∆V Line Regulation OUT/ ∆ (V V OUT + 0.2V) ≤ VIN ≤ 12.6V 90 400 µV/V IN Sourcing: 0 ∆VOUT/ ≤ IOUT ≤ 5mA 0.5 0.9 Load Regulation mV/mA ∆IOUT Sinking: -2mA ≤ IOUT ≤ 0 2.0 6.0 V Dropout Voltage (Note 4) IN - I V OUT = 1mA 50 200 mV OUT Short to GND 25 OUT Short-Circuit Current ISC mA Short to IN 25
MAX6061–MAX6068
∆V ppm/ Long-Term Stability OUT/ 1000hr at +25°C 62 time 1000hr Output Voltage Hysteresis ∆VOUT/ 130 ppm (Note 3) cycle
DYNAMIC CHARACTERISTICS
f = 0.1Hz to 10Hz 35 µVp-p Noise Voltage eOUT f = 10Hz to 10kHz 40 µVRMS ∆VOUT/ Ripple Rejection VIN = 5V ±100mV, f = 120Hz 76 dB ∆VIN Turn-On Settling Time tR To VOUT = 0.1% of final value, COUT = 50pF 115 µs
INPUT CHARACTERISTICS
Supply Voltage Range VIN Guaranteed by line-regulation test VOUT + 0.2 12.6 V Quiescent Supply Current IIN 90 125 µA Change in Supply Current IIN/VIN (VOUT + 0.2V) ≤ VIN ≤ 12.6V 3.4 8.0 µA/V
6 _______________________________________________________________________________________
