Datasheet MAX6061, MAX6062, MAX6063, MAX6064, MAX6065, MAX6066, MAX6067, MAX6068 (Analog Devices) - 8
Description | Precision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage References |
Pages / Page | 16 / 8 — Precision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage … |
File Format / Size | PDF / 559 Kb |
Precision, Micropower, Low-Dropout, High-Output-Current, SOT23 Voltage References ELECTRICAL CHARACTERISTICS—MAX6067, VOUT = 4.500V
(VIN = +5V, IOUT = 0, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX6067A (0.2%) 4.491 4.500 4.509 Output Voltage VOUT TA = +25°C V MAX6067B (0.4%) 4.482 4.500 4.518 Output Voltage Temperature MAX6067A 6 20 TCV ppm/°C Coefficient (Note 2) OUT MAX6067B 6 30 ∆V Line Regulation OUT/ ∆ (VOUT + 0.2V) ≤ VIN ≤ 12.6V 170 550 µV/V VIN ∆V Sourcing: 0 ≤ IOUT ≤ 5mA 0.5 0.9 Load Regulation OUT/ ∆ mV/mA IOUT Sinking: -2mA ≤ IOUT ≤ 0 2.4 8 V Dropout Voltage (Note 4) IN - IOUT = 1mA 50 200 mV VOUT Short to GND 25 OUT Short-Circuit Current ISC mA
MAX6061–MAX6068
Short to IN 25 ∆V ppm/ Long-Term Stability OUT/ 1000hr at +25°C 62 time 1000hr Output Voltage Hysteresis ∆VOUT/ 130 ppm (Note 3) cycle
DYNAMIC CHARACTERISTICS
f = 0.1Hz to 10Hz 55 µVp-p Noise Voltage eOUT f = 10Hz to 10kHz 55 µVRMS ∆V Ripple Rejection OUT/ ∆ VIN = 5V ±100mV, f = 120Hz 70 dB VIN Turn-On Settling Time tR To VOUT = 0.1% of final value, COUT = 50pF 230 µs
INPUT CHARACTERISTICS
Supply Voltage Range VIN Guaranteed by line-regulation test VOUT + 0.2 12.6 V Quiescent Supply Current IIN 90 125 µA Change in Supply Current IIN/VIN (VOUT + 0.2V) ≤ VIN ≤ 12.6V 3.2 8.0 µA/V
8 _______________________________________________________________________________________
