Datasheet ADRF5010 (Analog Devices) - 9
DescriptionSilicon SPST Switch, NonReflective, 100 MHz to 55 GHz
Pages / Page12 / 9 — ADRF5010. TYPICAL PERFORMANCE CHARACTERISTICS. INPUT POWER COMPRESSION …
File Format / SizePDF / 665 Kb
ADRF5010. TYPICAL PERFORMANCE CHARACTERISTICS. INPUT POWER COMPRESSION AND THIRD-ORDER INTERCEPT
ADRF5010 TYPICAL PERFORMANCE CHARACTERISTICS INPUT POWER COMPRESSION AND THIRD-ORDER INTERCEPT
Data Sheet
VDD = 3.3 V, VSS = −3.3 V, VCTRL = 0 V or VDD, TCASE = 25°C, 50 Ω system, unless otherwise noted.
Figure 13. Input 0.1 dB Power Compression vs. Frequency Figure 15. Input 0.1 dB Power Compression vs. Frequency (Low Frequency Detail) Figure 14. Input IP3 vs. Frequency Figure 16. Input IP3 vs. Frequency (Low Frequency Detail) analog.com Rev. 0 | 9 of 12
Document Outline Features Applications Functional Block Diagram General Description Specifications Single-Supply Operation Absolute Maximum Ratings Thermal Resistance Power Derating Curves Electrostatıc Dıscharge (ESD) Ratıngs ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Insertion Loss, Return Loss, and Isolation Input Power Compression and Third-Order Intercept Theory of Operation RF Input And Output Applications Information Evaluation Board Recommendatıons For Printed Circuit Board Design Outline Dimensions Ordering Guide Evaluation Boards
