Datasheet MAX6043 (Analog Devices) - 8
Description | Precision High-Voltage Reference in SOT23 |
Pages / Page | 16 / 8 — MAX6043. Typical Operating Characteristics. OUTPUT VOLTAGE vs. … |
File Format / Size | PDF / 2.5 Mb |
MAX6043. Typical Operating Characteristics. OUTPUT VOLTAGE vs. TEMPERATURE. LOAD REGULATION. (VOUT = 2.5V). (VOUT = 10V)
MAX6043
(VIN = +5V for VOUT = +2.5V, VIN = +10V for VOUT = +3.3V or +4.096V, VIN = +15V for VOUT = +5V or +10V, IOUT = 0, TA = +25°C, unless otherwise noted.)
OUTPUT VOLTAGE vs. TEMPERATURE OUTPUT VOLTAGE vs. TEMPERATURE LOAD REGULATION (VOUT = 2.5V) (VOUT = 10V) (SOURCING, VOUT = 10V)
2.5020 10.005 4 THREE TYPICAL UNITS 10.004 THREE TYPICAL UNITS 2.5015 10.003 2 MAX6043 toc01 MAX6043 toc02 10.002 MAX6043 toc03 T 2.5010 0 A = +25°C 10.001 TA = -40°C 10.000 -2 2.5005 9.999 (mV) -4 2.5000 9.998 9.997 -6 2.4995 9.996 ΔV OUT 9.995 -8 OUTPUT VOLTAGE (V) 2.4990 OUTPUT VOLTAGE (V) 9.994 9.993 -10 TA = +125°C 2.4985 9.992 -12 9.991 TA = +85°C 2.4980 9.990 -14 -40 -25 -10 5 20 35 50 65 80 95 110 125 -40 -25 -10 5 20 35 50 65 80 95 110 125 0 10 20 30 40 50 60 70 TEMPERATURE (°C) TEMPERATURE (°C) OUTPUT CURRENT (mA)
LOAD REGULATION LOAD REGULATION LOAD REGULATION (SOURCING, VOUT = 2.5V) (SINKING, VOUT = 10V) (SINKING, VOUT = 2.5V)
2.0 25 2.0 TA = +25°C TA = +25°C 1.5 20 1.5 MAX6043 toc04 MAX6043 toc05 MAX6043 toc06 1.0 15 TA = -40°C 1.0 0.5 TA = -40°C 10 0.5 TA = -40°C (mV) (mV) (mV) 0 5 0 T ΔV OUT A = +25°C -0.5 ΔV OUT 0 ΔV OUT -0.5 -1.0 T -5 -1.0 A = +125°C TA = +85°C -1.5 -10 TA = +85°C -1.5 TA = +125°C TA = +85°C TA = +125°C -2.0 -15 -2.0 0 10 20 30 40 50 60 70 -4 -3 -2 -1 0 -3.0 -2.5 -2.0 -1.5 -1.0 -0.5 0 OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) OUTPUT CURRENT (mA)
LINE REGULATION LINE REGULATION MINIMUM INPUT-OUTPUT DIFFERENTIAL (VOUT = 2.5V) (VOUT = 10V) vs. LOAD CURRENT (VOUT = 2.5V)
0.1750 0.500 3.0 ΔVOUT / VOUT = 0.1% 0.1500 0.400 2.5 MAX6043 toc07 0.1250 MAX6043 toc08 T MAX6043 toc09 A = -40°C T T A = +125°C 0.300 A = +125°C 0.1000 2.0 TA = +25°C T (mV) 0.0750 0.200 A = -40°C T (mV) A = +85°C 1.5 TA = +85°C ΔV OUT 0.0500 ΔV OUT 0.100 0.0250 T T A = +25°C 1.0 A = +125°C 0 TA = +25°C 0 TA = -40°C TA = +85°C 0.5 -0.0250 -0.100 MINIMUM INPUT-OUTPUT DIFFERENTIAL (V) -0.0500 -0.200 0 4 8 12 16 20 24 28 32 36 40 12 16 20 24 28 32 36 40 0 20 40 60 80 INPUT VOLTAGE (V) INPUT VOLTAGE (V) LOAD CURRENT (mA) www.analog.com Analog Devices │ 8
