Datasheet MAX6043 (Analog Devices) - 9
Description | Precision High-Voltage Reference in SOT23 |
Pages / Page | 16 / 9 — MAX6043. Typical Operating Characteristics (continued). MINIMUM … |
File Format / Size | PDF / 2.5 Mb |
MAX6043. Typical Operating Characteristics (continued). MINIMUM INPUT-OUTPUT DIFFERENTIAL. POWER-SUPPLY REJECTION RATIO
MAX6043
(VIN = +5V for VOUT = +2.5V, VIN = +10V for VOUT = +3.3V or +4.096V, VIN = +15V for VOUT = +5V or +10V, IOUT = 0, TA = +25°C, unless otherwise noted.)
MINIMUM INPUT-OUTPUT DIFFERENTIAL POWER-SUPPLY REJECTION RATIO POWER-SUPPLY REJECTION RATIO vs. LOAD CURRENT (VOUT = 10V) vs. FREQUENCY (VOUT = 2.5V) vs. FREQUENCY (VOUT = 10V)
3.0 0 0 ΔVOUT / VOUT = 0.1% 2.5 -20 -20 MAX6043 toc10 TA = -40°C MAX6043 toc11 MAX6043 toc12 2.0 -40 -40 TA = +25°C 1.5 -60 -60 TA = +85°C PSRR (dB) PSRR (dB) 1.0 TA = +125°C -80 -80 0.5 -100 -100 MINIMUM INPUT-OUTPUT DIFFERENTIAL (V) 0 -120 -120 0 20 40 60 0.1 1 10 100 1000 0.1 1 10 100 1000 LOAD CURRENT (mA) FREQUENCY (kHz) FREQUENCY (kHz)
OUTPUT IMPEDANCE SUPPLY CURRENT vs. INPUT VOLTAGE SUPPLY CURRENT vs. INPUT VOLTAGE vs. FREQUENCY (VOUT = 2.5V) (VOUT = 10V)
100 480 440 T 440 TA = +125°C TA = +85°C 400 A = +125°C TA = +85°C 400 MAX6043 toc13 ) MAX6043 toc14 360 MAX6043 toc15 Ω 10 360 320 320 280 280 240 T 1 240 T A = +25°C T A = +25°C 200 200 A = -40°C TA = -40°C 160 160 OUTPUT IMPEDANCE ( 0.1 SUPPLY CURRENT (µA) 120 SUPPLY CURRENT (µA) 120 80 80 40 40 0.01 0 0 0.1 1 10 100 1000 0 4 8 12 16 20 24 28 32 36 40 0 4 8 12 16 20 24 28 32 36 40 FREQUENCY (kHz) INPUT VOLTAGE (V) INPUT VOLTAGE (V)
SUPPLY CURRENT vs. TEMPERATURE SUPPLY CURRENT vs. TEMPERATURE OUTPUT NOISE-VOLTAGE DENSITY (VOUT = 2.5V) (VOUT = 10V) vs. FREQUENCY
440 440 10,000 VIN = 5V V 420 420 IN = 15V √Hz) MAX6043 toc16 400 MAX6043 toc17 400 MAX6043 toc18 380 380 360 360 VOUT = 10V 340 340 1000 320 320 SUPPLY CURRENT (µA) 300 SUPPLY CURRENT (µA) 300 280 280 VOUT = 2.5V 260 260 OUTPUT NOISE-VOLTAGE DENSITY (nV/ 240 240 100 -40 -25 -10 5 20 35 50 65 80 95 110 125 -40 -25 -10 5 20 35 50 65 80 95 110 125 0.1 1 10 100 1000 TEMPERATURE (°C) TEMPERATURE (°C) FREQUENCY (Hz) www.analog.com Analog Devices │ 9
