Datasheet MAX6138 (Analog Devices) - 3
Description | 0.1%, 25ppm, SC70 Shunt Voltage Reference with Multiple Reverse Breakdown Voltages |
Pages / Page | 13 / 3 — Electrical Characteristics—MAX6138_21 (2.048V). PARAMETER. SYMBOL. … |
File Format / Size | PDF / 2.4 Mb |
Electrical Characteristics—MAX6138_21 (2.048V). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS
MAX6138 0.1%, 25ppm, SC70 Shunt Voltage Reference with Multiple Reverse Breakdown Voltages
(IR = 100μA, TA = -40°C to +85°C, unless otherwise noted. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX6138A (0.1%) 2.0460 2.0480 2.0500 Reverse Breakdown Voltage (Note 2) VR TA = +25°C MAX6138B (0.2%) 2.0439 2.0480 2.0521 V MAX6138C (0.5%) 2.0378 2.0480 2.0582 Minimum Operating Current IRMIN 45 65 µA Reverse Voltage Temperature Coefficient TC 4 25 ppm/°C (Notes 2, 3) Reverse Breakdown IRMIN ≤ IR ≤ 1mA 0.3 1.0 Voltage Change with ∆VR/∆IR mV Operating Current Change 1mA ≤ IR ≤ 15mA 2.5 8.0 Reverse Dynamic Impedance (Note 3) ZR IR = 1mA, f = 120Hz, IAC = 0.1IR 0.3 0.8 Ω Wideband Noise eN 10Hz ≤ f ≤ 10kHz 28 µVRMS Reverse Breakdown Voltage Long-Term Stability ∆VR t = 1000h 120 ppm
Electrical Characteristics—MAX6138_25 (2.5V)
MAX6138A (0.1%) 2.4975 2.5000 2.5025 Reverse Breakdown Voltage (Note 2) VR TA = +25°C MAX6138B (0.2%) 2.4950 2.5000 2.5050 V MAX6138C (0.2%) 2.4875 2.5000 2.5125 Minimum Operating Current IRMIN 45 65 µA Reverse Voltage Temperature Coefficient (Notes 2, 3) TC 4 25 ppm/°C Reverse Breakdown Voltage Change with Operating ∆VR/∆IR IRMIN ≤ IR ≤ 1mA 0.3 1.0 mV Current Change Reverse Breakdown Voltage Change with Operating Current ∆VR/∆IR 1mA ≤ IR ≤ 15mA 2.5 8.0 mV Change Reverse Dynamic Impedance (Note 3) ZR IR = 1mA, f = 120Hz, IAC = 0.1IR 0.3 0.8 Ω Wideband Noise eN 10Hz ≤ f ≤ 10kHz 35 µVRMS Reverse Breakdown Voltage Long-Term Stability ∆VR t = 1000h 120 ppm www.maximintegrated.com Maxim Integrated │ 3
