Datasheet MAX6173, MAX6174, MAX6175, MAX6176, MAX6177 (Analog Devices) - 10
Description | High-Precision Voltage References with Temperature Sensor |
Pages / Page | 20 / 10 — Typical Operating Characteristics (continued). OUTPUT IMPEDANCE vs. … |
File Format / Size | PDF / 4.1 Mb |
Typical Operating Characteristics (continued). OUTPUT IMPEDANCE vs. FREQUENCY. OUTPUT IMPEDANCE. (VOUT = 2.5V)
MAX6173–MAX6177 High-Precision Voltage References with Temperature Sensor
(VIN = +5V for VOUT = +2.5V, VIN = +15V for VOUT = 4.096V and VOUT = +10V, IOUT = 0, TA = +25°C, unless otherwise noted.)
OUTPUT IMPEDANCE vs. FREQUENCY OUTPUT IMPEDANCE OUTPUT IMPEDANCE (VOUT = 2.5V) vs. FREQUENCY (VOUT = 4.096V) vs. FREQUENCY (VOUT = 4.096V)
toc13b toc13c 100 100 100 COUT = 0 COUT = 1µF ) 10 MAX6173 toc13 ) 10 10 Ω 1 1 1 PEDANCE (Ω PEDANCE (Ω) 0.1 0.1 OUTPUT IM OUTPUT IM OUTPUT IMPEDANCE ( 0.01 0.01 0.01 0.001 0.001 0.001 0.01 0.1 1 10 100 1000 0.001 0.01 0.1 1 10 100 1000 0.001 0.01 0.1 1 10 100 1000 FREQUENCY (kHz) FREQUENCY (kHz) FREQUENCY (kHz)
SUPPLY CURRENT vs. INPUT VOLTAGE SUPPLY CURRENT SUPPLY CURRENT vs. INPUT VOLTAGE (V vs. INPUT VOLTAGE (VOUT = 4.096) OUT = 2.5V) (VOUT = 10V)
400 toc14b 400 400 TA = +125°C TA = +125°C 350 350 350 MAX6173 toc14 MAX6173 toc15 300 A) 300 300 ( 250 TA = +25°C 250 ENT TA= +25°C 250 TA = +25°C T 200 A = -40°C CURR 200 200 LY 150 150 150 TA = -40°C SUPP SUPPLY CURRENT (µA) 100 100 SUPPLY CURRENT (µA) 100 50 50 50 COUT = 0 0 0 0 0 5 10 15 20 25 30 35 40 0 5 10 15 20 25 30 35 40 0 5 10 15 20 25 30 35 40 INPUT VOLTAGE (V) INPUT VOLTAGE (V) INPUT VOLTAGE (V)
SUPPLY CURRENT vs. TEMPERATURE SUPPLY CURRENT SUPPLY CURRENT vs. TEMPERATURE (VOUT = 2.5V) vs. TEMPERATURE (VOUT = 4.096V) (VOUT = 10V)
350 375 toc16b 375 COUT = 0 MAX6173 toc16 350 350 MAX6173 toc17 325 325 325 300 300 300 SUPPLY CURRENT (μA) SUPPLY CURRENT (µA) 275 SUPPLY CURRENT (µA) 275 275 250 250 250 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) www.maximintegrated.com Maxim Integrated │ 10 Document Outline _GoBack
