Datasheet MAX6161 (Analog Devices) - 8
Description | Precision, Micropower, Low-Dropout, High-Output-Current, SO-8 Voltage References |
Pages / Page | 17 / 8 — Electrical Characteristics—MAX6167 (VOUT = 4.500V). PARAMETER. SYMBOL. … |
File Format / Size | PDF / 2.7 Mb |
Electrical Characteristics—MAX6167 (VOUT = 4.500V). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. DYNAMIC CHARACTERISTICS
MAX6161–MAX6168 Precision, Micropower, Low-Dropout, High-Output-Current, SO-8 Voltage References
(VIN = +5V, IOUT = 0, TA = TMIN to TMAX, unless otherwise specified. Typical values are at TA = +25°C.) (Note 1)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
MAX6167A 4.498 4.500 4.502 Output Voltage VOUT TA = +25°C V MAX6167B 4.495 4.500 4.505 Output Voltage Temperature MAX6167A 2 5 Coefficient (Note 2) TCVOUT ppm/°C MAX6167B 4 10 Dropout Voltage (Note 4) VIN - VOUT IOUT = 1mA 50 200 mV Line Regulation ΔVOUT/ ΔV VOUT + 0.2V ≤ VIN ≤ 12.6V 160 450 µV/V IN Sourcing: 0 ≤ I Load Regulation ΔVOUT/ OUT ≤ 5mA 0.6 0.9 ΔI mV/mA OUT Sinking: -2mA ≤ IOUT ≤ 0 2.3 8.0 Short to GND 110 OUT Short-Circuit Current ISC mA Short to IN 25 Long-Term Stability ΔVOUT/ time 1000hr at +25°C 80 ppm/ 1000hr Output Voltage Hysteresis ΔVOUT/ (Note 3) cycle 125 ppm
f = 0.1Hz to 10Hz 55 µVp-p Noise Voltage eOUT f = 10Hz to 10kHz 55 µVRMS Ripple Rejection VOUT/VIN VIN = 5V ±100mV, f = 120Hz 70 dB Turn-On Settling Time tR VOUT to 0.1% of final value, COUT = 50pF 230 µs
INPUT CHARACTERISTICS
Supply Voltage Range VIN Guaranteed by line-regulation test VOUT + 0.2 12.6 V Quiescent Supply Current IIN 100 120 µA Change in Supply Current ΔIIN/ΔVIN VOUT + 0.2V ≤ VIN ≤ 12.6V 3.1 8.0 µA/V www.maximintegrated.com Maxim Integrated │ 8
