19-2266; Rev 2; 6/03 3ppm/°C, Low-Power, Low-DropoutVoltage ReferenceMAX6133General DescriptionFeatures The MAX6133 high-precision, low-power, low-dropout ♦ Low Temperature Coefficient voltage reference features a low 3ppm/°C (max) temper- 3ppm/°C (max), SO ature coefficient and a low dropout voltage (200mV, 5ppm/°C (max), µMAX max). This series-mode device features bandgap tech- nology for low-noise performance and excellent accura- ♦ Tiny 5mm ✕ 3mm µMAX Package cy. Load regulation specifications are guaranteed for ♦ Low 200mV (max) Dropout Voltage source currents up to 15mA. The laser-trimmed, high- stability thin-film resistors, together with post-package ♦ Low 40µA Quiescent Current trimming, guarantee an excellent initial accuracy specifi- ♦ ±0.04% (max) Initial Accuracy cation (0.04%, max). The MAX6133 is a series voltage reference and consumes only 40µA of supply current ♦ Low 16µVP-P Noise (0.1Hz to 10Hz) (2.5V Output) (virtually independent of supply voltage). Series-mode ♦ 15mA Output Source-Current Capability references save system power and use minimal external components compared to 2-terminal shunt references. ♦ Wide 2.7V to 12.6V Supply Voltage The MAX6133 is available in 8-pin µMAX and SO pack- ♦ Excellent Line (30µV/V, max) and ages. The unique blend of tiny packaging and excellent Load (0.05mV/mA, max) Regulation precision performance make these parts ideally suited for portable and communication applications. Selector GuideApplications Precision Regulators SUFFIXVOLTAGE OUTPUT A/D and D/A Converters 25 2.500V Power Supplies 30 3.000V High-Accuracy Industrial and Process Control 41 4.096V Hand-Held Instruments 50 5.000V Ordering InformationMAXIMUM INITIALMAXIMUM TEMPCOPARTTEMP RANGEPIN-PACKAGEACCURACY (%)(ppm/°C, -40 ° C to +85 ° C) MAX6133A_ _ -40°C to +125°C 8 µMAX 0.06 5 MAX6133AASA_ _ -40°C to +125°C 8 SO 0.04 3 MAX6133BASA_ _ -40°C to +125°C 8 SO 0.08 5 Note: Two-number part suffix indicates output voltage option. Typical Operating CircuitPin Configuration TOP VIEW SUPPLY INPUT IN REFERENCE N.C. 1 8 I.C.* OUTPUT OUT IN 2 7 N.C. 0.1 0.1 MAX6133 µF* µF MAX6133 N.C. 3 6 OUT GND 4 5 I.C.* GND SO/ µ MAX *INPUT CAPACITORS ARE OPTIONAL. *INTERNALLY CONNECTED, DO NOT CONNECT. ________________________________________________________________ Maxim Integrated Products1For pricing, delivery, and ordering information, please contact Maxim/Dallas Direct! at 1-888-629-4642, or visit Maxim’s website at www.maxim-ic.com.
