Datasheet SG-8002 (Epson) - 2
ManufacturerEpson
DescriptionCrystal Oscillator Programmable
Pages / Page6 / 2 — External dimensions and Recommended footprint. SG-8002CE. Ceramic SON …
File Format / SizePDF / 700 Kb
External dimensions and Recommended footprint. SG-8002CE. Ceramic SON 4pin 3.2x2.5x1.05 mm. E125.0C. SC181A. SG-8002CA
External dimensions and Recommended footprint SG-8002CE Ceramic SON 4pin 3.2x2.5x1.05 mm E125.0C SC181A SG-8002CA
SG-8002CE
SG-8002JA
Crystal oscillator
(Unit:mm)
3.20.2 C (ex.0.01 µF) 2.2 #4 #3 #3 #4 1.4
E125.0C
2. 0 #4 #3  9. 5 0 .
SC181A
2 7 2. 1 0 #2 9 #1 #1 #2 . 0.9 1 5 1.0 5 0.1 #1 #2 2.4 Resist
SG-8002CA Ceramic SON 4pin 7.0x5.0x1.4 mm
1.8 1.4 C #4 #3 #4 #3 (ex. 0.01 μF) .0 2. 2 0
E 125.000
± .6 .0 2 5
PHC935C
.2 4 #1 #2 #2 5.08 #1 Resist 7.0±0.2 1 5 5.08 . 1. 0 0 + - 41. 5.08
SG-8002JC SOJ 4pin 10.5x5.8x2.7 mm
Package and pin compatible with SG-636. 10.5 Max. 1.3 #4 #3 The metal case inside of the molding com- x. pound may be exposed on the top or bottom
E125.0000 C
0 of this product. .1 Ma 2 5 This purely cosmetic and does not have any 8.
2PH 9357B
5 effect on quality, reliability or electrical specs. .6 4 #1 #2 .x Ma 7.2 0.51 (1.0) (1.0) 5.08 5.08 0.05Min. 3.6 Note. OE Pin (PT, PH, PC) Pin map To maintain stable operation, provide a OE Pin = "H" or "open": Specified frequency output. Pin Connection 0.01uF to 0.1uF by-pass capacitor at a loca- OE Pin = "L": Output is high impedance. 1 OE or ST tion as near as possible to the power source terminal of the crystal product (between VCC - ST Pin (ST, SH, SC) 2 GND GND). ST Pin = "H" or "open": Specified frequency output. 3 OUT ST Pin = "L": Output is low level (weak pull - down), oscillation 4 VCC stops. Document Outline SG-8002series_E187.pdf QMEMS_E152
