Datasheet SSA23L, SSA24 (Vishay) - 2
Manufacturer | Vishay |
Description | High Current Density Surface-Mount Schottky Rectifier |
Pages / Page | 5 / 2 — SSA23L, SSA24. ELECTRICAL CHARACTERISTICS. SSA23L. SSA24. PARAMETER. TEST … |
File Format / Size | PDF / 134 Kb |
SSA23L, SSA24. ELECTRICAL CHARACTERISTICS. SSA23L. SSA24. PARAMETER. TEST CONDITIONS. SYMBOL. UNIT. TYP. MAX. TYP. MAX. Notes
SSA23L, SSA24
www.vishay.com Vishay General Semiconductor
(TA = 25 °C unless otherwise noted)
SSA23L SSA24 PARAMETER TEST CONDITIONS SYMBOL UNIT TYP. MAX. TYP. MAX.
TJ = 25 °C 0.43 0.45 0.45 0.49 Maximum instantaneous forward voltage (1) 2.0 A VF V TJ = 125 °C 0.32 0.38 0.36 0.42 TJ = 25 °C - 0.5 - 0.2 Maximum reverse current at rated V (2) R IR mA TJ = 125 °C 15 25 12 20
Notes
(1) Pulse test: 300 μs pulse width, 1 % duty cycle (2) Pulse test: Pulse width ≤ 40 ms
THERMAL CHARACTERISTICS
PARAMETER SYMBOL SSA23L SSA24 UNIT
RθJA 110 Typical thermal resistance (1) °C/W RθJL 28
Note
(1) Aluminum substrate mounted
ORDERING INFORMATION
(Example)
PREFERRED P/N UNIT WEIGHT (g) PREFERRED PACKAGE CODE BASE QUANTITY DELIVERY MODE
SSA23L-E3/61T 0.064 61T 1800 7" diameter plastic tape and reel SSA23L-E3/5AT 0.064 5AT 7500 13" diameter plastic tape and reel SSA23LHE3_A/H (1) 0.064 H 1800 7" diameter plastic tape and reel SSA23LHE3_A/I (1) 0.064 I 7500 13" diameter plastic tape and reel
Note
(1) AEC-Q101 qualified Revision: 23-Apr-2020
2
Document Number: 88882 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
