Datasheet SSA23L, SSA24 (Vishay) - 3
ManufacturerVishay
DescriptionHigh Current Density Surface-Mount Schottky Rectifier
Pages / Page5 / 3 — SSA23L, SSA24. RATINGS AND CHARACTERISTICS CURVES
File Format / SizePDF / 134 Kb
SSA23L, SSA24 RATINGS AND CHARACTERISTICS CURVES
SSA23L, SSA24
www.vishay.com Vishay General Semiconductor
(T
A
= 25 °C unless otherwise noted) 2.5 Axis Title 100 10000 ) T = 150 °C J A 2.0 10 (m T = 125 °C J rrent (A) 1 urrent 1.5 1000 C 0.1 ard Cu e rw line verse lin line o 0.01 1.0 e R 1st 2nd 2nd s T = 25 °C J age F 0.001 100 er SSA23L v 0.5 A SSA24 0.0001 stantaneou 0.00001 0 In T = -40 °C J 0 25 50 75 100 125 150 0.000001 10 Lead Temperature (°C) 0 20 40 60 80 100 P t f R t d P k R V lt (%) Fig. 1 - Forward Current Derating Curve Fig. 4 - Typical Reverse Characteristics 70 1000 T = 25 °C J 60 f = 1.0 MHz V = 50 mV sig p-p 50 40 100 30 ard Surge Current (A) orw 20 nction Capacitance (pF) u ak F J e 10 SSA23L P SSA24 0 10 1 10 100 1 10 100 Number of Cycles at 60 Hz Reverse Voltage (V) Fig. 2 - Maximum Non-Repetitive Peak Forward Surge Current Fig. 5 - Typical Junction Capacitance Axis Title 100 10000 ) (A rrent 10 u C 1000 e rd a lin orw 1 T = -40 °C F J 2nd s T = 25 °C J 100 0.1 T = 125 °C J stantaneou In T = 150 °C J 0.01 10 0 0.2 0.4 0.6 0.8 1.0 Instantaneous Forward Voltage (V) Fig. 3 - Typical Instantaneous Forward Characteristics Revision: 23-Apr-2020
3
Document Number: 88882 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
