Datasheet BRT21, BRT22, BRT23 (Vishay) - 6
ManufacturerVishay
DescriptionOptocoupler, Phototriac Output, Zero Crossing
Pages / Page9 / 6 — BRT21, BRT22, BRT23
File Format / SizePDF / 203 Kb
BRT21, BRT22, BRT23
BRT21, BRT22, BRT23
BRT21, BRT22, BRT23
www.vishay.com Vishay Semiconductors 0.6 400 40 Hz to 60 Hz 0.5 Line operation, 300 Ptot = f (ITRMS) 0.4 (mA) (W) 0.3 200 tot P I TRMS 0.2 ITRMS = f(TPIN5), RthJ-PIN5 = 16.5 K/W 100 Thermocouple measurement must be performed potentially separated 0.1 to A1 and A2. Measuring junction as near as possible at the case. 0 0 0 100 200 300 50 60 70 80 90 100 I iil410_08 T iil410_11 PIN5 (°C) TRMS (mA) Fig. 8 - Current Reduction Fig. 11 - Power Dissipation 40 Hz to 60 Hz Line Operation 103 12 Tj = 25 °C t V gd = f (IF/IFT 25 °C), VD = 200 V Tj = 100 °C f = 40 to 60 Hz, Parameter: Tj 10 (V) 8 102 (µs) f gd Tj = 25 °C DINH min. V 5 DINH min = f (IF/IFT25°C), T V 6 j = 100 °C parameter: Tj Device zero voltage switch can be triggered only in hatched are 4 below Tj curves. 101 100 5 101 5 102 100 5 5 102 101 iil410_09 IF/IFT25 °C iil410_12 IF/IFT25 °C Fig. 9 - Typical Trigger Delay Time Fig. 12 - Typical Static Inhibit Voltage Limit 103 Tj = 25 °C 100 °C 1 6 102 5 (µA) 2 5 0.1 µF 220 V~ I DINH 101 3 4 5 IDINH = f (IF/IFT 25 °C), VD = 600 V, Parameter: Tj 100 0 2 4 6 8 10 12 14 16 18 20 iil410_13 iil410_10 IF/IFT25 °C Fig. 10 - Typical Inhibit Current Fig. 13 - Apply a Capacitor to the Supply Pins at the Load-Side Rev. 2.1, 21-Jun-2023
6
Document Number: 83690 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
